Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 406 sbc cooling advice
Old 03-02-2012, 07:31 PM
kraftada kraftada is offline
Ok data first
sbc 406, retro roller, rhs pro action heads iron (steam holes drilled), 3 core aluminum rad, rad is behind a condensor, going in my 84 vette and will end up with about 350 - 400 hp. Crusier occasionally getting into it.
1 High flow water pump or not.
2 What fan switch thermostat combo do I go with? e.g. stat 170 with fan switch on at 190 off at 180.
3 Do in need to route any coolant lines from the back to front to help flow.
Thank all
