406 sbc cooling advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2012, 07:31 PM
Ok data first
sbc 406, retro roller, rhs pro action heads iron (steam holes drilled), 3 core aluminum rad, rad is behind a condensor, going in my 84 vette and will end up with about 350 - 400 hp. Crusier occasionally getting into it.
Questions:
1 High flow water pump or not.
2 What fan switch thermostat combo do I go with? e.g. stat 170 with fan switch on at 190 off at 180.
3 Do in need to route any coolant lines from the back to front to help flow.
Thank all
Old 03-03-2012, 06:00 PM
lg1969's Avatar
Google "Tunnel Ram 406"
I would use a 170* thermostat switch and get a 160* thermostat. Get the biggest electric fan.
Old 03-03-2012, 08:47 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
When I had my K5 Blazer I used a 180 deg thermostat with adjustable fan switch. The switch was set to turn the fans on at 205 and shut off at 190. Don't be afraid to let the engine get to 200. It's not going to hurt it. This was a supercharged 350 and I used a stock style copper tube 4 core radiator that came stock in the 3/4 and 1 ton pickups from the early 70s. The fans were Flex -a-Lite dual 12". They worked very well.
GM 3.1L Cooling issues and cooling fan pickled_asparagus Modern Electronic Engines 11 05-21-2013 06:46 PM
Experienced painters advice please! Advice on painting a frame El Campo Hotrodding Basics 25 03-13-2012 03:21 PM
Cooling SBC 34jeff Engine 7 05-18-2010 04:16 PM
cooling e.g.r. air.... sc2dave Engine 5 02-21-2006 05:28 PM
