406 sbc knocking noise at idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2011, 08:39 PM
rotnrobbie's Avatar
in memory of roy taft
Hello I have a 7o nova with a 406 small block. A couple days ago I noticed this intermittant knocking noise. Its only when its idling once I give it some gas it goes away until I let off again and it slowly returns. Any ideas?
Old 03-21-2011, 09:04 PM
tnovot's Avatar
You don't say what your oil pressure is at idle but SBC's typicaly do not need alot at idle.
Could be a rod bearing, crank damper, any belt driven accesory, piston slap if it occurs when cold but goes away when warm.
Is the noise coming from bottom end? Front of engine? from trans or converter area if A/T. You can use a hose or long handled screwdriver as a stethescope to help locate the noise. You will get more opinions and advice if you provide more info. Need to know more about symptoms, conditions, etc.
Terry
Old 03-21-2011, 09:16 PM
The first time I had a bad cam it knocked at idle,wouldn't when reved or driving.At idle the knock would come and go.I had convinced myself that it must be a wrist pin but when I tore it down a lobe on the cam was wiped out.Strange thing though it ran pretty good.It sounded like tapping on a valve cover with a screw driver handle.A low pitch clunk.
Old 03-21-2011, 11:00 PM
rotnrobbie's Avatar
The oil pressure at idle when its worm is about 20 on my gauge thats how its always been im not seeing a drop or change in anything. I just swapped my carb from a qjet to a holley 750 double pumper about three weeks ago. I have a 700r4 trans runnin 4 10s in the rear. I drive it about 3 to 4 times a week just around town some freeway. The noise sounds like its coming from under the intake manifold or the carb. ive checked my valves and everything for noise but I cant pinpoint it. My starter went out right after I got the carb installed so I changed that. I drove it today after I checked my valves and rods and all that and when I get on the throttle real good for like 2 seconds the engine gets real loud (more so than it should) but than seems to quite down and everything is normal. Could I maybe have a torque convertor issue? Or my fly wheel? I really dont think its a rod cause than wouldnt it just make the noise all the time? it only in idle worm or cold it doesnt matter. Maybe something is loose im going to dig into it more tomorrow I was just looking for ideas. Thank you
Knocking Noise RenoValron Engine 5 09-28-2005 08:34 PM
Knocking noise RetroJoe Engine 15 08-17-2004 08:01 PM
Knocking noise, HELP! Please!! fireforsin Engine 4 01-04-2004 12:31 PM
knocking noise during idle and full throttle 89camaroman Engine 8 10-18-2003 10:01 PM
Knocking noise? MichaelB Transmission - Rearend 7 08-19-2003 08:03 AM
