Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 03-29-2008, 10:15 PM
Canadian78 Canadian78 is offline
406 sbc top end suggestions
Im going to buy parts for my engine soon. Want to get some ideas on what parts to get. This motor is going into my 78 Malibu. I want to get 400+ hp and be pretty street able This is my short block. New Scat crank, 5.7 rods and dished kb pistons.
Im probably going with patriot heads.(I know but there cheap and im only in high school) What parts for the rest of the motor do you guys recommend.
Old 03-29-2008, 11:16 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
re: 406 sbc top end suggestions
Cylinder Heads 400 block steam holes need to be drilled. Your machinist that built your short block can do this for you
400SBC head gaskets
Camshaft
Intake manifold hand port match to the heads (#1205 intake gasket)
Carburator
Ready to Run distributor
(no spark box required)
Rocker arms
Needs a 10" 3500 stall torque converter and 3.73-4.10 gears
Old 03-30-2008, 12:29 AM
SnottyAust's Avatar
SnottyAust SnottyAust is offline
GTS Monaro Coupe 406
Id say same as FBird but get the 1010 Felpro headgaskets, for alloy heads only, that have a copper core and so dont dent the alloy heads too much.
Even on a low budget id use head studs...far far superior !
Invetsigate the RPM Air Gap manifold for a non-screamer...
Old 03-30-2008, 12:50 AM
F-BIRD'88's Avatar
Yada Yada Yada
I avoid using head studs on simple street motors, as they can tend to leak coolant, requiring teardown. Ok, and even prefered on a race motor that gets torn down often, but for this motor you are better off with new GMPP cylinder head bolts.
Add head bolt washers under each head bolt to avoid galling the aluminum head bolt seat.
The felpro #1010 had gasket is not for a 400SBC block. It does not have steam holes. The gasket bore size is not big enough.
If you buy a quality cylinder head cast of quality heat treated aluminum as the
Summit/Brodix IK heads are, you won;t have a problem with the #1014 felpro gasket on aluminum.
Some things are not worth cutting corners on. The quality of the aluminum alloy and heat treat of a cylinder head casting is one of those areas.
Brodix's propriority aluminum is heavy duty high quality and heat treated. I believe T6 spec (hard). Any brinelling will be minimal, if at all with the 1014 gasket and proper bolt torque spec.. if you ever have a problem, say the combustion chamber is damaged somehow, or what ever, Brodix can and do weld repair their heads.
Worth the extra $100
A cylinder head made of inferior material will not be as tough and is more likely to brinell. It is also more difficult to repair, if that situation arises.
These heads come with the right springs for the Cam listed.
No direct experience with Patriot heads. Ya get what you pay for.
Old 03-30-2008, 01:29 PM
thanks a lot for the advice. Yeah im a little iffy on the patriot heads. I have heard some good things and some really bad. I was going to try them out because I don't got huge budget as im only in highschool and I want to get my car done before graduation in June.
Old 03-30-2008, 02:02 PM
F-BIRD'88's Avatar
Yada Yada Yada
Then you don't have enough money to do it twice.
Spend the few extra dollars for a quality made, trouble free head.
Old 03-30-2008, 02:31 PM
ap72 ap72 is offline
****** '72 Cutlass Supreme
You guys have some really radical parts for a 400hp goal. I would just go with a 268 cam, a RPM AirGap intake, Vortec heads, long tube headders, and a quadrajet carb. It'll not only put out the power you want, but more importantly have a LOT of torque down low which is what you need in a street engine. You may want to invest in a few extra sets of tires after that- if you drive anything like I did in highschool every stoplight is an opportunity for a burn out.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "406 sbc top end suggestions"
list your 400 or 406 sbc combo's here,,, what works the best for you tiresmoke55 Engine 15 10-20-2008 12:13 AM
Critique my 406 SBC build Chevtec Engine 5 10-18-2006 01:57 PM
Top Chop to '50's Pickup. F-1Rodder Hotrodders Knowledge Base 7 04-14-2005 02:22 PM
Sbc 406 sb72elcamino350 Engine 9 03-05-2004 11:59 AM
Edelbrock Performer - more top end nova69 Engine 1 02-14-2003 05:31 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
