406 setup needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2008, 12:41 PM
406 setup needed
Hi,
Hello guys i was wondering if you could recomend any setup for my ride.My car is a street 1983 firebird with headers th350 2500 stall and 3.42 gears.I just bougth a 406 short block wich have stock 3.75 crank,5.7 x-rod,je forged flat top 5cc pistons.I would like to know witch heads,cam and intake would work for my street setup.I already have a edelbrock 800 carb.And does my rear end will support the engine?
thanks.
Old 07-21-2008, 02:56 PM
Last journal entry: Albany Oregon Show
406 Setup
I forget if the 83 Firebird has rear coils and torque bar. If it does replace upper and lower control arms and torque bar with solid aftermarket system. Do what you have to to stabilize and control the rear end. If you run street tires it might live for awhile. Your 406 needs bigger lungs it will like aftermarket aluminum heads with about 200 to 215 cc intake runners. With aluminum heads and premium gas you can run 10.5 to 1 compression. Put in a cam with about 550 lift and 230to 240 duration @ 50 and 110 center. Top it off with an RPM Air Gap and your carb and you have a basic combo.
Bob
Old 07-21-2008, 03:02 PM
What are your intension for the car?
Daily driver?
Is mpg important?
What octane fuel do you what to buy?
Do you want a smooth idle?
Old 07-21-2008, 03:15 PM
here is some good 406 reading for chevy high performance (impersonator II)
http://www.chevyhiperformance.com/te...d/rockers.html
406 cid, 9.5:1 vortec head, 230 degree cam, 428hp/525ftlbs
406 cid, 9.5:1 180cc AFR head, 230 degree cam, 490hp/529ftlbs, 87 octane
Old 07-21-2008, 03:22 PM
406 Setup
http://www.ryanscarpage.50megs.com/combos2.html
Read and pick check out Combos 63-68, 69-76 and 101-107
Bob
68 camaro nitrous setup 71corvette Engine 7 07-02-2008 12:51 PM
Machining Info. Needed GoneNova/406 Engine 10 06-22-2006 09:22 PM
Is my Torque Converter too big for my setup ?? 74NovaRat Engine 15 02-01-2005 09:23 AM
406 cam/heads combination needed Sixty9Vette Engine 20 09-07-2004 09:29 PM
406 Help Needed MI2600 Engine 2 06-14-2004 07:18 PM
