Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 406 small block questions
Old 08-24-2008, 05:05 PM
badsle badsle is offline
Hi all,
I am currently putting my 400 chev into a 82 model holden commodore ,
its 30 over as the title indicates and i chose to use a set of world sportsman 2 heads, they have 64cc chambers and that brings my comp with the trw forgies up to around 11:1 ...the heads have had a mild port job and the cam is 590 intake lift 609 exh lift, 268,271 duration @50 and 106 lobes ,
just wondering whether you think im on the right track to get 500hp out of this motor , it has turned without a drama to 6500 before, its got steel rods and balanced and blueprinted good bolts and forged slugs.
it has edelbrock rpm performer with 1" plastic spacer and 830 annular holley . and full barry grant fuel supply .
custom made tri y 13/4 to 21/4 to 3" headers with twin 3" exhaust .
full msd ignition etc .
i am hoping to run high 10 sec qtrs in this car as it is only 3100 pound with 28" tyre 4500 stall converter and 4.11 rear gears, do you tink im on the right track , is there anything i should check out or get looked at that you guys think i may have overlooked , i know about the steam holes but anything else would be much appreciated .
