406 small block questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2008, 05:05 PM
Hi all,
I am currently putting my 400 chev into a 82 model holden commodore ,
its 30 over as the title indicates and i chose to use a set of world sportsman 2 heads, they have 64cc chambers and that brings my comp with the trw forgies up to around 11:1 ...the heads have had a mild port job and the cam is 590 intake lift 609 exh lift, 268,271 duration @50 and 106 lobes ,
just wondering whether you think im on the right track to get 500hp out of this motor , it has turned without a drama to 6500 before, its got steel rods and balanced and blueprinted good bolts and forged slugs.
it has edelbrock rpm performer with 1" plastic spacer and 830 annular holley . and full barry grant fuel supply .
custom made tri y 13/4 to 21/4 to 3" headers with twin 3" exhaust .
full msd ignition etc .
i am hoping to run high 10 sec qtrs in this car as it is only 3100 pound with 28" tyre 4500 stall converter and 4.11 rear gears, do you tink im on the right track , is there anything i should check out or get looked at that you guys think i may have overlooked , i know about the steam holes but anything else would be much appreciated .
Old 08-24-2008, 05:56 PM
No idea on horsepower estimate but I can tell you that thing is going to haul.
Old 08-24-2008, 06:06 PM
thanks heaps ...im hoping it goes hard ...just hope it stays together for a while ....
Old 08-24-2008, 06:20 PM
thanks for that f-bird . , the heads have had a mild port and good grind on the valves with he guides taken back a bit, im not looking at going full hog straight out as i want something to do later , i worked out that with my 28" tyre and 4.11 gears it will trap at about 130mph at 6600, just worried about big revs in a 400 ,,,,cheers chris
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 07:26 AM
does the small block chevy have a "proper" name? Hoxviii Hotrodders' Lounge 62 11-21-2009 07:50 PM
My 350 Small Block Chevy. What do I have? Frank the Tank Engine 29 09-08-2007 06:33 PM
400 Small Block Questions Dark Jester Engine 3 07-08-2005 11:02 PM
big block or small block ford? stangfiend Engine 3 12-10-2002 09:55 AM
