Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 406 small block review
  #29 (permalink)
Old 01-06-2013, 02:09 AM
BuzzLOL BuzzLOL is offline
Cars, Trucks, Boats
.. A 650 CFM - 750 CFM carb. or even stock Q-Jet 4 bbl. carb. is plenty...
.. Stock oil pan and oil pump is fine at this performance level... maybe add a high pressure bypass spring to stock oil pump or use a high pressure oil pump... I would avoid the power-consuming high volume pumps as unneeded ... add a windage tray if it doesn't already have some kind of one inside the oil pan...
.. What's your tranny? If it's an automatic shifting at only 3800-4000 RPMs at WOT, then it'll need governor springs to bring that up to 6000 or so for the engine to make its new power... or manually shift it when wanting that power... If a manual tranny, of course it can still simply be shifted as desired...
.. Whether you need/desire a different stall RPM torque converter will depend a lot on your current rear end ratio... and driving habits... and final cam choice... and final compression ratio...
