406 Starting and High RPM Issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2010, 06:25 AM
From the help everyone has provided in my previous thread: 406 sbc, build questions
I have a great running engine with some very impressive power (at least for my application) However, I do have a couple issues that I don't seem to be able to tackle.
1) It is a bear to start! I have a high torque starter that spins the engine easily until it starts to fire... and then it struggles until it fires
2) At higher RPM's and under load, the engine sounds like my valves are loose (or as I've heard others say, it "Diesels")
I'm leaning towards ignition issues but I'm not 100% sure... I have a pretty much stock HEI system except for a recurve kit in the distributor. Any thoughts?
(I've started collecting parts: MSD Billet Distributor, Blaster 2 coil, Mallory Wires... and looking for a MSD 6AL box)
Old 05-16-2010, 07:42 AM
My first thought would be to check the timing. It sounds like you may be running too much advance.
Old 05-16-2010, 10:58 AM
T-bucket23's Avatar
Wiki Edits: 26
Sounds like you are to far advanced. This is not a good situation. If you dont get it under control you can cause severe engine damage.
What is your base timing and total timing without vacuum advance connected
Chet
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
1978 Pontiac 400 (oil exiting engine at high RPM) sLiKNiCk Engine 9 04-19-2010 07:54 PM
327 in 88 Truck pete379 Engine 101 01-19-2006 09:03 PM
rattling at low or high rpm IROC-russ Transmission - Rearend 4 09-15-2004 11:50 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
