Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 406 vs 377 small block chev
Old 03-21-2011, 07:45 PM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
Originally Posted by mcc1
i understand that the 400 has a poor rod ratio so going to the shorter throw makes sense but when i run the engine on a symulator it tells me the piston speed is to high and failure is highly probable. im going to use aftermarket rods and pistons to help lower the recipricating mass but is 6500 rpm to high
IMHO no 6500 is not to high someone may say different but i know with my 408 6500 is easy. 5.7 x beam rods flat top pistons dart iron eagle heads and more. I guess something to think about is just how often are you going to be bouncing off 6500 RPMs anyway.
JMO
Cole
