-   -   406 vs 377 small block chev (http://www.hotrodders.com/forum/406-vs-377-small-block-chev-194913.html)
mcc1 03-21-2011 06:21 PM
hi my name is mario i am currently building a drag car from a mercedes benz 300 coupe and would like to ask your opinions on the following engine combinations. i have a 400 small block chev that iwould like to put in the car. the combination is with a 700r4 trans, an 8.8 diff from a mustang
the consern is rpm
your thoughts would be appreciated
mario
eloc431962 03-21-2011 06:24 PM
And exactly what do you mean your concerns are RPMs ?
Cole
mcc1 03-21-2011 06:40 PM
Cole
i understand that the 400 has a poor rod ratio so going to the shorter throw makes sense but when i run the engine on a symulator it tells me the piston speed is to high and failure is highly probable. im going to use aftermarket rods and pistons to help lower the recipricating mass but is 6500 rpm to high
eloc431962 03-21-2011 06:45 PM
IMHO no 6500 is not to high someone may say different but i know with my 408 6500 is easy. 5.7 x beam rods flat top pistons dart iron eagle heads and more. I guess something to think about is just how often are you going to be bouncing off 6500 RPMs anyway.
JMO
Cole
mcc1 03-21-2011 06:55 PM
every weekend weather permitting
DoubleVision 03-22-2011 04:44 AM
Build your 400. Use 5.7 rods. Have the bottom end balanced by a good shop and you`ll come out alright.
ap72 03-22-2011 10:02 AM
The bigger concern is your transmission choice. There's no sense in running a 700 when a TH350 will do a better job and cost much less.
Chevrolet4x4s 03-22-2011 08:19 PM
Unless that 700 is built,it isn't going to live long.
Shane
American Muscle 03-22-2011 09:29 PM
How much street use are you planning? If not alot id go powerglide with some 4:10 or higher gears
