406 vs 377 small block chev - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2011, 06:21 PM
hi my name is mario i am currently building a drag car from a mercedes benz 300 coupe and would like to ask your opinions on the following engine combinations. i have a 400 small block chev that iwould like to put in the car. the combination is with a 700r4 trans, an 8.8 diff from a mustang
the consern is rpm
your thoughts would be appreciated
mario
Old 03-21-2011, 06:24 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
And exactly what do you mean your concerns are RPMs ?
Cole
Old 03-21-2011, 06:40 PM
Cole
i understand that the 400 has a poor rod ratio so going to the shorter throw makes sense but when i run the engine on a symulator it tells me the piston speed is to high and failure is highly probable. im going to use aftermarket rods and pistons to help lower the recipricating mass but is 6500 rpm to high
Old 03-21-2011, 06:45 PM
eloc431962's Avatar
Wiki Edits: 37
IMHO no 6500 is not to high someone may say different but i know with my 408 6500 is easy. 5.7 x beam rods flat top pistons dart iron eagle heads and more. I guess something to think about is just how often are you going to be bouncing off 6500 RPMs anyway.
JMO
Cole
Old 03-21-2011, 06:55 PM
every weekend weather permitting
Old 03-22-2011, 04:44 AM
DoubleVision's Avatar
Build your 400. Use 5.7 rods. Have the bottom end balanced by a good shop and you`ll come out alright.
Old 03-22-2011, 10:02 AM
Banned
The bigger concern is your transmission choice. There's no sense in running a 700 when a TH350 will do a better job and cost much less.
Old 03-22-2011, 08:19 PM
Unless that 700 is built,it isn't going to live long.
Shane
Old 03-22-2011, 09:29 PM
American Muscle's Avatar
305 Turbo-Fire 240hp
How much street use are you planning? If not alot id go powerglide with some 4:10 or higher gears
Chev Small Block Viberation rackum Engine 17 09-01-2006 09:40 PM
small block into 52 chev sedan neil francis Suspension - Brakes - Steering 1 10-02-2005 08:20 AM
odd small block chev nigelh Engine 15 08-21-2005 08:39 AM
small block chev ocoeelin Engine 2 08-18-2003 04:41 PM
Installing a chev small block in the rear of an chev s-10 vegadeth Body - Exterior 11 07-16-2002 03:16 PM
