406ci motor specs.
406ci, 4.155 x 3.75
9.8:1 factory 400 block Scat cast steel crank Oliver 6 inch rods SRP 21cc dish pistons 1/16, 1/16, 3/16 rings Moroso 7 qt. oil pan Mellings oil pump Comp Cams solid flat tappet 236/242 @ .050,0.501/0.510-inch Intake Centerline 106 1.6:1 full roller tip stainless rockers Factory iron 041X heads w/hardened seats Gasket Matched and ported a little 2.02/1.60 inch valves Professional Products Crosswinds Intake Holley 3310-1 780 cfm Carburetor HEI Davis Unified Ignition Street/Strip 1 3/4 headers w/3 inch exhaust |
OK, we see some motor specs. What next??
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
Working on that right now...
This Motor is going into a 71 C-10 truck Probably not the best thing to put it in, but it's what I have...? Any body have any good ideas about getting this thing to hook up? |
I guess we will see, still about a month or so out?
It has 4" lowering coil springs in the rear, and is a 12 bolt 3.08 posi? May have to upgrade the shocks, they came with the lowering kit. Tires are 295/50R15? |
The 3.08 gear won't help but those tires will be the biggest problem. A 50 series tire has to have a very stiff side wall to keep it from collapsing which translates into a very hard tire. You can use them but don't expect any traction....specially in a P/U. That 406 (properly built) will put out gobs of torque right from the git go, find some sticky street/strip tires and a 3.73 gear set and you'll be much better off.
I'd swap the rear tires to a drag radial. I'm using M&H drag radials in the back of my gasser, and even without a run through the water box, they still hook up better than almost anything I've ever run.
You might also think of a way to add some hidden weight in the rear bumper to help plant the tires. A better rear gear ratio will help too. |
Thanks for the input! I will look into changing my set up for sure!
Moving the tank back between the frame rails, and battery in the bed?
The cam is pretty small for a 400. You can tighten up the valve lash to good effect
to get more effective "cam" .004" to .006" (set cold) tighter than the cam card hot lash spec Get a real deal 10" high stall and 4.10's and some short sticky 8.5x26" ET streets. Does your truck have the leaf spring rear suspension or the swing arm rear suspension? |
The truck has a coil spring rear end with control arms.
I am going to get a stall converter for it. |
AirLift air bags (drag bags) will increase traction when you need it.
Lowering the truck changes the geometry of the rear suspension making it squat on acceleration. The air bags correct this as well as balancing the left right tire traction bias making your limit slip posi work really really good. Now you have adjustable ride height and adjustable traction (rear axle geometry) by adjusting the air in the air bags. Simple and effective. The stock OEM suspension bushings can be upgraded with polyeurathane bushings. |
| My 406ci motor will only idle correctly with vac adv off. | 69c10_99 | Engine | 2 | 05-16-2012 09:31 AM |
| need help finding out info and specs on motor and heads | hplus8 | Engine | 4 | 05-01-2011 11:11 AM |
| 406ci w/ blower? need help | Joshua Lee | Engine | 4 | 01-11-2010 11:36 AM |
| 406ci compression | SBCfan04 | Engine | 3 | 04-03-2008 01:47 PM |
| 406ci in the making.. | 406ci | Engine | 23 | 01-06-2007 12:54 PM |
