408 sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2012, 06:27 PM
408 sbc
Hey guys I need a little input but no jibber-jabber please
I picked up a 40 over 400/408 sbc that has a decent cam{don't have the specs}
and has the stock 487 heads 194/150 75cc
I have a set of 041 heads 202/160 64cc that I was thinking of using
the bottom end is all cast with speed pro flat-tops and an 040 head gasket
My concern is will the 041 heads give me problematic compression .Should I go to a thicker head gasket to lessen the compression or just put the fat heads back on
My peek rpm range will around 5500 This is for a mud truck
Thanks,Bob.
"Chance favors the prepared mind"
Old 03-17-2012, 06:43 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
No "jibber-jabber"? I don't know if we can do that...
Find a compression calculator and figure out what you want, do a search here to see what's reasonable for c.r. Here's just one of many.
So far, with the 75cc heads, gasket and other info you provided, assuming 6 cc valve cuts on flat tops, you're at about 9.74:1, with 64cc heads you'll be at 10.48. This considering the piston is .025 in the hole.
Semper Fi
Old 03-17-2012, 07:26 PM
408 sbc
Perhaps jibber-jabber was a rather poor choice of phrases, pistons are flush without gasket ,I guess its been decked , 4 v/relief on the pistons.
As long as I can run it on pump gas I'm o.k. with it but I'm concerned if I get into the 11's with my compression I'm gonna have problems with detonation?
Old 03-17-2012, 08:15 PM
lg1969's Avatar
Google "Tunnel Ram 406"
I suggest to get Alum 64CC heads because it can handle higher compression then the iron heads. It lowers the BTU in the chamber therefore less heat.
Hope this helps.
Old 03-18-2012, 06:45 AM
408 sbc
heat is definitly NOT my friend with a 408 so I'm really interested in ways to keep the temp down .Since this is a zero deck block should I go to a 051 head gasket?
Thanks,Bob..
Old 03-18-2012, 08:26 AM
Cam specs would be helpful, as the intake closing point determines the dynamic compression ratio.
However, Peak rpm at 5500 rpms would require a small cam and will not tolerate much compression on pump gas.
You should consider setting up for E85 if you plan to use 64cc heads with a 408 with flat tops and a mild cam.
Old 03-18-2012, 02:12 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Zero deck, 64cc with a .051 gasket still nets you 11.25:1. Going much thicker on the gasket wrecks your quench.
Semper Fi
Old 03-18-2012, 02:39 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 this is about what i have with my 408.
Cole
