40's Model Chevy Coupe - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-25-2012, 12:03 AM
1971BB427's Avatar
If you could go the Jag, it would have been very nice, even i you had to take a road trip to a larger town in Wa. or Id.
I would definitely go for a GM tilt column from a 80's car or pickup. The tilt will make things nicer to get the correct driving position and beel comfortable.
  #17 (permalink)
Old 01-25-2012, 12:00 PM
I will look in harder for the Jag front end and see what I can find. What years and model did you suggest again? XJ6? As far as the chevy tilt column goes, do they look good once place or do they look out of place? The interior I am leaving mostly original with maybe just a few upgrades like seats and safety stuff I think, I havent absolutely gotten to that point yet. Been mostly concerned with power plant and drive train. Thanks again.
  #18 (permalink)
Old 01-25-2012, 03:51 PM
1971BB427's Avatar
The Chevy tilt column looks great as long as you don't use the factory wheels. My buddy's '40 has the tilt from a late 70's Camaro, and it had the factory wheel when he bought the car. He changed to a simple old school 3 spoke and what a difference!
  #19 (permalink)
Old 01-25-2012, 04:21 PM
spacytracy's Avatar
Last journal entry: 1957 Chevrolet 3100 Truck Small Window to Big Window Conversion
1940 chevrolet coupe build
I recently finished my 38 chev. coupe with a TCI mustang 11 front end with 2" drop spindles. I also bought rear spring set up from Posies that will bolt into your existing spring mounts and added 2 inch lowering blocks. I did use the TCI rear cross member for the shock mounts. These two set ups will lower your car about 5 1/2". The frame on your car is very similar in design to my 38 frame. It is a top hat design and is already boxed from the factory, so IMHO you would be crazy to drop additional money and time to put a different frame in. TCI front end bolts in using mostly original mounting holes, and only requires welding on the spring hats.
Of course if you chop your top like I did, you will really get it down low. Good luck!
  #20 (permalink)
Old 01-26-2012, 09:11 AM
TCI huh, I will check out there products and see. I looked a bit harder at the coupe and it is actually a '39, so I think it should def. work with what you are suggesting. The spring ride you put on, does it go down the road pretty smoothly being it is leaf springs? That was one of my concerns that it would be too stiff. Im glad to know that you can get it lower useing springers too cause I was afraid of that as well. As you can see I havent done this before, hence why I am asking so many questions. Thanks.
  #21 (permalink)
Old 01-26-2012, 09:20 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i would love it if both of you, spacytracy and spec4, would post some pics and share some info over in the 37 & 38 +/- thread I am trying to collect some info and pics for all of us old gm owners to share
  #22 (permalink)
Old 01-26-2012, 02:42 PM
spacytracy's Avatar
I could not be more pleased with ride quality and cornering. I still have not put roll bars on, and dont feel that I really need them. Low center of gravity has aided in handling. I did cut my front coils 1/2 coil before the car had settled and probably will change out the front coils with stock heights as the car is about 1" lower in front than I would like. TCI setup only took my one Saturday to fully install. I did hire a pro. welder to weld the spring caps on for me, but have since mastered the art of welding after chopping the top and repairing the deck lid and could weld them myself next time. Good luck on your project. Jhan.
My 40's Coupe texas boy Hotrodding Basics 16 01-17-2011 05:41 PM
Jag XJ6 IFS install on 40's Chevy 40ChevyJim Suspension - Brakes - Steering 3 05-19-2010 08:08 AM
31 model a coupe Dons31A Hotrodding Basics 8 05-02-2008 10:01 AM
40's Plymouth coupe gas tank??? hemicoupe Hotrodding Basics 6 03-05-2006 12:39 AM
pic request: 40's ford spring mounted ontop axle for model a 29modela Suspension - Brakes - Steering 1 02-08-2006 09:00 AM
