41 Chev Coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2010, 02:27 PM
41 Chev Coupe
I Have A 41 Chev Coupe With A 1953 6 Cyl Truck Eng.
It Has A 3 Spd. Tranny W/ 3 On The Tree. I Want To Find Out How I Can Convert It To A Power Glide Tranny Or
Perahaps A 350 Automatic. Will I Have To Rework The
Driveline, Fabercate New Tranny Mounts,use An Adapter To Bolt The Tranny To The Engine?
Any Info. You Can Give Me Will Be Very Helpfull.
Thanks, Auto Nut
Old 01-08-2010, 05:39 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks, Auto Nut
the answer is yes to most of your questions..
modern trans will need expensive adapter to the old engine.
new mounts, cross member built.
the car should have a closed drive line.. that will require a rear differential change, more fab work.
god luck , have fun
41 ford coupe fabricator Hotrodding Basics 13 04-05-2015 08:32 AM
Does anybody have a pair of 37-38 chev coupe doors? Footstomper Body - Exterior 0 03-22-2009 07:20 AM
1935 Chev 3w Coupe engine idea's Redneck32 Hotrodders' Lounge 12 01-29-2008 01:56 PM
how to chop 41 chev coupe longhare Body - Exterior 20 01-28-2006 10:52 PM
37 chev coupe 40 pontiac coupe duke mauk Introduce Yourself 2 01-25-2006 12:50 PM
