41 chevy door hinges - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2004, 10:30 AM
badriand's Avatar
Does anyone know where I can get replacement door hinges for a 41 chevy truck? i had to drill the bolts out of mine because they were bad rusted.
Old 04-08-2004, 10:43 AM
willys36@aol.com's Avatar
Wiki Edits: 21
If you have trouble finding a good replacement you might try a trick I have used before. Fill the damaged hole in your hinge as deep as you can with brass brazing using oxy/acetylene. Then simply drill out the hole on drill press with the proper number or letter bit for snug fit on a new pin.
