41 chevy tire rub - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2013, 01:33 AM
41 chevy tire rub
I have this 41 chevy with a early nova or camaro sub frame and the tires rub when I turn. If I,m careful I can drive it almost anywhere,and I do, but I,m getting tired of being so careful. I have another uncut 41 frame and I know I should use it and put a IFS in front but the work and money are just to much. And the car drives,steers and sits so nice the way it is!If I could jut find smaller rims and maybe some taller springs. Does any one know what rims might give me a inch . I now have 14 by 6 olds rims and I can't find anything smaller that will clear the disc brakes.Any thoughts?
The Following User Says Thank You to cuppy65 For This Useful Post:
fwinter01 (02-07-2013)
Old 02-07-2013, 03:01 AM
Banned
if it is indead a g.m. front clip.. the lug pattern.. you can get wheels in any backspace/width you'd ever need..
is it rubbing on the outer fender or inner..
changing the backspacing is all you'll need.. to move the rim in or out..
Old 02-07-2013, 02:46 PM
tire rub
Yes the tire hits the fender. I was hoping to find a junk yard set of rims that were 14x5 but I don't think they ever made rims that narrow for disc brake cars. Chevy bolt pattern 5 x 4.75
Old 02-07-2013, 03:44 PM
jaw22w's Avatar
What is the backspacing on your current rims? Just get rims with 1" less backspacing. That should fix the rub.
Old 02-07-2013, 04:00 PM
There are also narrower control arms made to bring the wheels in, I think Fatman has them but they are quite a few bucks. And here lies the reason I sold off my Camaro subbed frame for my truck, they are just too much trouble for what you get. I had a very narrow stock 65 Skylark 14 inch wheel and it still rubbed the fender at full lock. There may be some cool old 4" Centerlines with 5:20s or something that would work.
Old 02-07-2013, 07:29 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
If on the front suspension that you have, the upper a-arm mounts inboard of the frame mount you can install longer upper inner a-arm bolts and move the upper control arm in 1/2 to 3/4". Then, if you can weld or know someone who can, cut and narrow the lower control arm the same 1/2" to 3/4" (this is a good time to replace the lower ball joints).
If the upper control arm is outboard of the frame mount, you will have to cut and shorten that one as well.
You may have to trim the inner and outer tie rod ends a bit to make up for the narrowing to set the toe, but there may be enough adjustment without having to do that.
Doing this will alter the suspension geometry but narrowing only a small amount won't cause any issues with normal driving and is a cheap way to improve or eliminate a clearance issue with the outer fender lip.
Regards,
Andy
Old 02-07-2013, 07:47 PM
41 ya
So glad that your building that post war project, sorry I can't help with your issues but YA get great build
Old 02-07-2013, 08:56 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I am wondering if you can turn the lip on the fender and gain just enough to get the clearance that you need??
Sam
Old 02-08-2013, 01:08 PM
I dured this problem on a 46 Chevy by using S10 4x4 steel wheels. They have 2" more offset in. Unfortunately they only come in 15". 78 to 85 Riv anf Toro uses rge same wheel. The only change I had to make to the front suspension was to use Chevelle steering arms which are shorter, and a bit higher, to clear the inner edge of the rim. Yes, I know the Chevelle is front steer, but you can reverse them for rear steer.
Old 02-08-2013, 01:34 PM
aosborn's Avatar
Wiki Edits: 7
Didn't reversing the steering arms seriously screw up the ackerman angle?
Old 02-08-2013, 02:44 PM
rub
Thanks everyone for the ideas. I found a pair of 14x5 steel wheels with a 3.5 inch backspace that should clear the disc caliper . That and some higher springs should make it better
Old 02-08-2013, 03:02 PM
pic
Thought i would try to post a few pic. One is the 41 chevy I've been driving and the other is a 50 dodge I have almost done.
Name:	41 front.jpg
ID:	71194   Click image for larger version
Old 02-08-2013, 04:40 PM
The arm angles out when on the front, it angles in when you reverse them. The Ackerman seems to be ok, the car drives nice.
Old 02-20-2013, 07:45 AM
455olds's Avatar
Nice looking cars.
Old 03-07-2013, 09:43 AM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Yes GM did make a 14x5x4.75 also a 13x5x 4.75 they were on 65 66 corvairs ,the bottle shape not the square body ,i have one 13 that was a spare tire but some one shoulkd have plenty,these are steel wheels.
will tire fit or too big and Rub?? kingofny1997 Suspension - Brakes - Steering 4 09-17-2012 06:15 PM
1957 chevy with tire rub bowtie.2 Hotrodding Basics 4 12-29-2010 06:19 AM
65 chevelle tire rub...sway bar? lngliv3 Suspension - Brakes - Steering 23 10-26-2010 09:15 PM
Tire Rub 86 Cougar LS Introduce Yourself 2 09-16-2004 12:33 PM
tire paint that wont rub off? blndweasel General Rodding Tech 2 04-30-2003 12:03 PM
