-   -   41 chrysler subframe (http://www.hotrodders.com/forum/41-chrysler-subframe-92800.html)
Mrwood 06-30-2006 10:07 PM
Want to install a new subframe on my 41 chrysler royal, anyone have any ideas as to what subframe to use. I want to update the suspension for a better ride and steering. But want to keep the old flathead six engine.
bates_k 07-02-2006 07:11 PM
For something that heavy, I'd be looking for an Aerostar
van, rack and pinion steering, decent brakes, and a good
sized ARB...
Keith
johnnymopar 07-02-2006 08:04 PM
if you're going to keep the original engine then don't waste your time subframing the car.
you should be able to get some aftermarket kits for your car like brake upgrades, power rack upgrade and sway bar kits, etc.
ply-do is one place that has a lot of stuff available.
JB
Mrwood 07-02-2006 09:00 PM
JB
Do you have a website for this company.I want to keep this car stock looking, but have a nice steering and suspension. As this is a nice looking old car.
johnnymopar 07-03-2006 12:34 PM
i found their ad in rod and custom. they don't have a website as far as i know.
tel (304) 475-3245, Delbarton , WV 25670. hours: 11am-6pm EST
apparently they have everything from '32-'52
good luck.
JB
Paddyboyy 07-25-2006 07:45 PM
I am building a '49 Chrysler and also retaining the original flathead and fluid drive.
As for the front end, a close look and you will see it is only slightly different from anything you would sub in. Kingpins are there instead of ball joints and that's about it.
Parts for rebuilding the front end are readily available.
There are 3-4 VERY good disc brake kits available. The one I am using is from www.rustyhope.com
A shock absorber relocation kit from Mr. Street Rod will relocate the upper shock mount to the frame where it will be much more effective.
Some scouting wrecking yards should turn up a beefier stabilizer bar to replace the stock one.
Ply-Do, as mentioned, has a very good R & P kit.
Do all that and you will have as good a front end as a swap would give you at a fraction of the cost and work and you have an uncut frame.
There are a few guys at www.P15-D24.com on the forum, who have done all of the above and more than willing to share their Mopar experiences.
Ask your question there and you will get more than a bit of useful info.
Good luck
Article from R&C on a '51 Plymouth. Suspension is the same except for the steering knuckle(spindle). I have replaced the knuckle on my '49 with a Plymouth knuckle.
http://www.rodandcustommagazine.com/...lym/index.html
