41 chrysler subframe
Want to install a new subframe on my 41 chrysler royal, anyone have any ideas as to what subframe to use. I want to update the suspension for a better ride and steering. But want to keep the old flathead six engine.
Do you have a website for this company.I want to keep this car stock looking, but have a nice steering and suspension. As this is a nice looking old car. |
i found their ad in rod and custom. they don't have a website as far as i know.
tel (304) 475-3245, Delbarton , WV 25670. hours: 11am-6pm EST apparently they have everything from '32-'52 good luck. JB |
I am building a '49 Chrysler and also retaining the original flathead and fluid drive.
As for the front end, a close look and you will see it is only slightly different from anything you would sub in. Kingpins are there instead of ball joints and that's about it. Parts for rebuilding the front end are readily available. There are 3-4 VERY good disc brake kits available. The one I am using is from www.rustyhope.com A shock absorber relocation kit from Mr. Street Rod will relocate the upper shock mount to the frame where it will be much more effective. Some scouting wrecking yards should turn up a beefier stabilizer bar to replace the stock one. Ply-Do, as mentioned, has a very good R & P kit. Do all that and you will have as good a front end as a swap would give you at a fraction of the cost and work and you have an uncut frame. There are a few guys at www.P15-D24.com on the forum, who have done all of the above and more than willing to share their Mopar experiences. Ask your question there and you will get more than a bit of useful info. Good luck Article from R&C on a '51 Plymouth. Suspension is the same except for the steering knuckle(spindle). I have replaced the knuckle on my '49 with a Plymouth knuckle. http://www.rodandcustommagazine.com/...lym/index.html Last edited by Paddyboyy; 07-26-2006 at 08:40 PM. |
| starter help 41 chrysler | sideshowbobottawa | Hotrodding Basics | 4 | 04-23-2006 12:25 AM |
| 34 pontiac 81 camaro subframe install ? | mobythevan | Suspension - Brakes - Steering | 7 | 05-19-2005 12:17 PM |
| wheel cylinders for chrysler royal 41 | cakethetake | Suspension - Brakes - Steering | 7 | 02-08-2005 09:39 AM |
| anyone here use a camaro subframe in a '40s chrysler product? | coolP11 | Suspension - Brakes - Steering | 3 | 08-03-2004 10:18 PM |
| What is wrong with a chrysler | 68newport383 | Body - Exterior | 23 | 02-11-2003 04:35 AM |
