41 Ford 2door sedan - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2010, 09:19 PM
41 Ford 2door sedan
I am getting ready to start on my 41 tudor sedan.
It will be getting a 97model 4.6 and 4r70w.
The drive train and anything I can reuse will come from the 97 lincoln town car that I have procured already.
My main problem is the ford track width is 57" while the lincoln has a width of 64" so I am not thinking the rear end is going to work without needing to be narrowed. I was hoping to use it as it has rear disk brakes.
I was actually thinking about an attempt to reuse the front suspension but there again the track width is going to be just too wide.
So I am stuck wondering if there is anything other than a mII front that is an option for this.I am afraid that there is not much else out there.
Once I get both of these cars next to each other and do some more measuring maybe I will be surprised but I am not thinking the lincoln stuff will work.
Any suggesions or opinions would be appreciated!
Old 08-27-2010, 05:42 AM
We built a 41 Business Coupe and installed the OEM M II front end. This required a pretty healthy frame rail modification since the M II is ideally suited for the 35-40 frame width. The 41 frame is about 2.5 inches wider. We used a mid 80s GM rear (Monte/Camaro/TA) rear. The Big Lincoln front and rear will have to be narrowed in order to work and in my opinion is not worth going there. The smaller Lincoln Versilles (never could spell words with funny pronunciation) will work, but they are hard to come by. An interesting use of a 95/96 Big Ford LTD front end under a 63 Ford Pickup is being built by a friend of mine. I will get some dimensions of his frame to see if it might work under your 41. My impression is the track may be too wide, but deep wheel back spacing may work. Hugh brakes may not allow that, however.
Trees.
Old 08-30-2010, 12:12 PM
Actually the 41 was narrower than the 40 was and longer wheelbase.That is the reason frame manufacturers do not support it.It is an orphan! I love how I always wind up with the well...you bought the non standard car! OH well.I will overcome in the eng.Actually chassis engineering sells a kit I have found that bolts to the stock frame specifically for this car.NOT sure I want to do it.Seems too easy.I have a 9" that I can get narrowed.Or may get the 8.8 narrowed so I can use the rear disk.
Old 09-10-2010, 09:55 PM
Well guys.I have pretty much decided to do a drop axel and disk conversion.
I think I am just going to do rear leaves and modern rear end.wish me luck
41 Ford Business coupe frame montesrule Suspension - Brakes - Steering 4 03-13-2009 01:30 PM
Looking for frame specs on a 41 ford roadtriprod General Rodding Tech 2 01-09-2009 03:59 PM
41 Ford Top Chop Cowtown Punk Body - Exterior 4 11-09-2006 12:07 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
41 Ford Coupe vin number location dskinner53@otelco.ne Introduce Yourself 2 09-11-2005 11:05 PM
