41 Ford 4"drop spindles 205/70/16 tires in front. Problem is when turning tire rubs al little. Need to raise front about an inch. Buggy spring across front. Can this be raised without having steering problems?
Sure it can be raised.. I would propose a spacer placed in the spring perch to raise the car a bit..Most likely you will need to make one and hope the spring perch bolts are long enough to allow the installation of a spacer..
Mine is a completely different setup then yours but I had to go to a taller narrower tire for clearance.
Mine was hitting on the leading edge when I was turning and control arm was coming up.
Mine are 185-65-15 on 7" wheels.
I am using a MII suspension but It is an old aftermarket one and I had to install narrower control arms also.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
