41 outlaw willy's - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2007, 06:15 PM
41 outlaw willy's
I am helping build a outlaw performance pro street 41 willy's and have a little bit of problems on placing the column throught the floor and still having room for a brake pedal and gas pedal. I would like to see some pictures of how anybody else has done these cars. Please send them to badbowtie@zommtown.com
or post them on here.
Old 02-04-2007, 11:08 PM
powerrodsmike's Avatar
Wiki Edits: 161
Welcome to the board. Emailing pics defeats the purpose of the board. So we post them here for everyone to share.
I did this setup in a 33 pickup and freed up alot of floor space It has an added benefit of being a much more comfortable angle for the steering wheel to be on.
The double u jounts are available from Borgeson as well as Flaming river. The stub column is one that I cut down , but they are now available from Ididit.
I made all the bracketry and the brake pedal. It isn't beautiful, but it is very strong. The MC is firewall mounted.
There is also a company called steer clear that makes an offset drive that is very spiffy. It can let you use a stubby column but you don't have to use double U joints. Costs alot too.
Link .... http://www.wizardsteerclear.com/index.html
Hope this helps,
mikey
BTW, I did not do the welds on the firewall. That guy no longer works for me. They have been fixed.
Name:	stub column engine side.JPG
ID:	18212   Click image for larger version
Name:	stub column better.JPG
ID:	18213   Click image for larger version
Name:	stub column with brake pedal.JPG
BE different....ACT normal.
Old 02-05-2007, 12:49 AM
Are you using hanging pedals or through the floor pedals?
Most early cars have the front portion of the floor tilted up to the firewall (that known as toeboards). The floor pedals came up through a hole in the toeboard with plenty of clearance around steering column.
I have noticed that many glass body manufacturers make their bodies with a flat firewall dropping down to meet a flat floorboard at pretty much a 90 degree angle. Why they do this I have no clue, maybe it is to make the manufacturing process easier. BUT, one thing it does do is eliminate the toeboards which were engineered all those years ago(and continued today) to place their feet at a natural and non-tiring angel while riding/driving. This design change also causes this clearance problem for new builders not that familiar with car construction. Without the angled front of the floorpan, a new builder will tend to think the steering column should exit the body farther down than it should which causes the pedal clearance problem. Sometimes it is solved by someone pointing out the lack of toeboards, sometimes it is solved by bending up some really weird looking pedals.
Does your body have toeboards?? And why not?
Old 02-05-2007, 08:48 AM
Wiki Edits: 161
Putting any kind of v8 in a 41 willys makes finding a place for a steering column and pedals a chore. The trans tunnel gets alot bigger than stock, while the firewall gets moved back a bunch.
You wind up putting the column through the firewall at a point much lower than stock. At the fiberglass body manufacturer where I worked for 13 years, the firewall in our 34 coupe was recessed 4" and the toeboards were retained. The stock pedals were able to be used. The columns still needed to be angled down more to clear larger engines than stock. (41 willys came with a 4 cylinder)
The willys is already a small car, the rear of the front wheelwells intrude into the passenger compartment as well. There just is not alot of room for pedals .Toe kicks are nice for comfort, but in the case of a 41 willys, they don't dictate the position of the column.
Swinging pedals can help if you can stand seeing the MC on the firewall. Raising the column in the 2 ways that I described will help no matter where you put your pedals.
Just not having a column there to get in the way of your foot is a huge help. I have driven cars with the pedal on the left side of the column and had to use 2 feet to drive. It was uncomfortable and IMO unsafe.
Later,
Mikey
QUALITY 41 Willys bodies? Homeslice Body - Exterior 17 11-06-2009 10:46 AM
QUALITY '41 Willys bodies? Homeslice Hotrodders' Lounge 7 01-20-2008 11:43 AM
Street Beast 41 Willys bobthetran Hotrodders' Lounge 17 05-04-2006 12:14 PM
41 willys 41willys0 Introduce Yourself 2 08-18-2005 01:43 PM
41 Willys Seats. Harry Hut Interior 8 01-15-2004 08:53 AM
