41 pontiac frame change - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2010, 09:57 PM
I have a 41 Pontiac and thinking about a frame swap , which is closer to original fame size ,A S10 or full size truck frame ? I have a 80s full size on hand.
I also thought about a nova front sub frame , but hacking a frame in half and re welding it kinda i don't know ? Anyway what i shooting for is a classic car with new suspension , brakes rear end and other parts that can be easily replaced at a car parts store.
Old 07-07-2010, 10:48 AM
Wiki Edits: 49
GM vehicles of that vintage had "top hat" style frames which are very strong and they are easily capable of supporting big block power in stock form. So, unless your frame is extremely pitted and rusted through there's really no reason to replace it.
It is much less work to add an aftermarket front suspension and a new set of rear springs with an upgraded rear end than switching frames, at least for most people. But... its your car.
Good luck.
Old 07-07-2010, 11:48 AM
A "Frame swap" could also be called a "Money swap", "Time swap", or "work swap". All you do is "swap" money you would spend on the original frame, time spent on the original or work spent on the original and putting that same money, time and work into making a frame SORT OF fit a car it wasn't designed for.
It saves you NO money, NO time, and NO work!
Spend the time to find an original frame if you need it modify it to fit your needs with an IRS kit or what ever. But don't spend a bunch of money, time and work to put in the wrong frame!
41 Ford Business coupe frame montesrule Suspension - Brakes - Steering 4 03-13-2009 01:30 PM
86 s-10 frame bent catscan4free Suspension - Brakes - Steering 3 03-27-2007 09:46 PM
Critique My Frame STATUTORY GRAPE Suspension - Brakes - Steering 23 12-21-2005 08:51 PM
51 pontiac frame swap jellybean Suspension - Brakes - Steering 3 03-10-2004 11:28 AM
Picture of stock MII x-member in '41 Willys frame willys36@aol.com Suspension - Brakes - Steering 13 05-20-2003 12:51 PM
