41 willys with S-1- frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2003, 09:43 PM
Post 41 willys with S-1- frame
Hi Guys,
I am thinking about doing a 41 Willys coupe build up and I found a company that sells bodies and a frame setup based on a chev S-10 chassis. Basically you use an S-10 donor frame with front and rear suspension, or pro street the rear if that is the way you want to go. Does anyone have any first hand or close experiance with this build? thanx, Bob myers SD
Old 05-13-2003, 11:04 PM
Post
If the manufacturer has adapted his body to fit the S10 chassis properly and the wheelbase, steering column angle, engine mounting are all ok it sounds good. The S10 chassis is certainly adequate for the Willys conversion and that little baby would honk with the stock 4.3 V6!
Stay away from the Pro-street jazz. See my post about "Why is pro-street nightmare still around?".
Old 05-14-2003, 07:12 AM
Post
the manufacturer is at www.activepowerinc.com If anyone has the time, please check it out and let me know what you think. Thanx, Bob Myers.
