41 Willy's super gas - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2006, 02:50 PM
propaneburner's Avatar
Last journal entry: Artillery wheels
Hello all
This is maybe a stupid question.
But i couldn't helping thinking about it and i am wondering now.
We are building a Wily's drag car , and mounting the engine with solid mounting plates.
One front (between engine block and waterpump) and one ( between engine block and transmission).
My question now is what to do with the rear trans. mount use the rubber mount or make this one solid also????
And why of course.
Thanks for any info.
Wander.
Old 04-22-2006, 04:26 PM
LilSmoke's Avatar
Use a poly trans mount. If you dont,it will break the case when the chassis torques.
Old 04-25-2006, 07:43 AM
41Willys S/G
Lilsmoke is right. You'll need some sort of crossmember with a poly or rubber mount to support the trans tailshaft.Otherwise you'll absolutely crack the trans. Also,while on the subject, you should install an engine limiter. It should be installed on either side of the engine between the engine and the frame,mounted diagonally,either toward the frt. or rr. whichever space permits. Hope that helps. Batstar70
street beast kit cars ( 41 willys ) ceckstn Hotrodding Basics 7 11-25-2010 07:52 AM
Help Please? 87 Dodge mini-ram van - stalling if little gas applied jojo99 Engine 3 07-27-2005 06:19 PM
41 willys with S-1- frame bob myers General Rodding Tech 2 05-14-2003 06:12 AM
building a frame for a 41 willys jorden67 Hotrodders' Lounge 0 01-04-2003 07:27 PM
steel willys gas tank americarkid Hotrodders' Lounge 0 04-30-2002 08:25 PM
