4100 front cover - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2005, 12:03 PM
4100 front cover
Hi. Ive Got A 86 Cad 4100 V8 Deville,need To Replace One Of The Torx Head Bolts In The Front Cover. My Caddy Service Manual Sdays To Unbolt Lower Ball Joint And Tie Rod End To Gain Room To Lower The Right Side Frame Rails. My Question Is: Will I Need To Support The Lower Control Arm When I Did Connect The Ball Joint, Or Will It Just Loosen Up. I Have Had Fun Trying To Get The Water Pump Off As The Torx Head Bolts Are Real Tight In The Aluminum Fron Cover. Thanks
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Please all read... want to start a BIG project knowldgeisfatal Suspension - Brakes - Steering 58 06-29-2005 07:55 AM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 09:20 AM
mustang front clip Stangman196700 Body - Exterior 2 09-24-2004 07:43 PM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
