Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 412cui build Advice
Old 08-22-2012, 07:33 AM
cdminter59 cdminter59 is offline
412cui build Advice
Is this going to be a high compression engine or a pump gas engine. If you check what is run on 383's and 400's most run large intake runners so I would go with the 210's. Years ago I built a 383, 9.5 compression, mechanical roller cam 240/250 duration, Victor Jr. with a 750 Speed Demon. I went with the iron head Motown 220's. The higher the duration the bigger the heads. If it's a street only car I would use the 195's.
