Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 412cui build Advice
Old 08-22-2012, 10:12 AM
Scandinavian's Avatar
Scandinavian Scandinavian is offline
http://www.backfalt.fi/indexse
Last journal entry: Torque Converter
Originally Posted by cdminter59 View Post
Is this going to be a high compression engine or a pump gas engine. If you check what is run on 383's and 400's most run large intake runners so I would go with the 210's. Years ago I built a 383, 9.5 compression, mechanical roller cam 240/250 duration, Victor Jr. with a 750 Speed Demon. I went with the iron head Motown 220's. The higher the duration the bigger the heads. If it's a street only car I would use the 195's.
11.4 to 11.5 pump gas
it wil just se the street ven its rime for car inspection. 30km on the street every year!
