-   -   412cui build Advice (http://www.hotrodders.com/forum/412cui-build-advice-223191.html)
Scandinavian 08-22-2012 04:00 AM
412cui build Advice
Im planing to build a 412 cid engine
bore 4.155 stroke 3.800
Single plane intake
cam 12-678-4
so how big intake runners do i need im thinking AFR heads
will the 195s bee to small? do i need 210s?
cdminter59 08-22-2012 08:33 AM
412cui build Advice
Is this going to be a high compression engine or a pump gas engine. If you check what is run on 383's and 400's most run large intake runners so I would go with the 210's. Years ago I built a 383, 9.5 compression, mechanical roller cam 240/250 duration, Victor Jr. with a 750 Speed Demon. I went with the iron head Motown 220's. The higher the duration the bigger the heads. If it's a street only car I would use the 195's.
Scandinavian 08-22-2012 10:12 AM
11.4 to 11.5 pump gas
it wil just se the street ven its rime for car inspection. 30km on the street every year!
vinniekq2 08-22-2012 11:59 AM
CR is a small part of an engine build.I would stay under 11 for the 94 octane gas that I can buy.Intake runner size really depends on HP you need/want and what you call good manners if it matters? I use 227 cc intake runners and it drives good. I also use a medium solid roller and 950 cfm carb.434 cubes...for me
