The 413 Mopar - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2008, 05:59 PM
wretched ratchet's Avatar
one full turn after it squeeks
The 413 Mopar
Does anyone have any pros or cons on the 413 Mopar engine? I have absolutely no knowledge or experience with that motor and would appreciate any information that y'all might have.
Thanks,
WR
Old 07-27-2008, 08:34 PM
techinspector1's Avatar
Wiki Edits: 326
413/426 wedge/440. All the same basic RB (raised block) motor.
Old 07-27-2008, 10:17 PM
Thanks,
WR
Ya, we have a couple as well as 440s.
Biggest thing about hot rodding one is that only custom ground pistons are available, so you end up with a cost to build that is higher than a 440.
Joe has a Dodge like this in the works with the 413 long rams.
A 440 long ram is on the stand.
ID:	31501   Click image for larger version
Old 07-28-2008, 12:28 AM
DR132's Avatar
Sophisticated Minimalist
awesome engines in my opinion...basically a small bore 440, or more accurately a 440 is basically a bored 413...I'm a fan of them, I like the way the numbers sound as well ...check out www.allpar.com, theres info on just about everything MOPAR there and they have a couple pages with some good info on the 413 and 426 wedge engines...they were pretty stout engines and the high performance Max Wedge versions set alot of records basically if you have easy access to one and would rather have a big block mopar thats not a 440 then go for it otherwise a 440 would be alot easier to find and get some parts for, such as pistons as mentioned above plus a 440 would just have more balls equally built...not that you could honestly say a built 413 would be lacking in that department
Old 07-28-2008, 01:31 AM
Sir Joab's Avatar
MOPAR Guy
Last journal entry: Restoration of my Chrysler
An excellent engine. One of my favorites. With the "long ram" intake manifold it produced more torque than the 440! (495 ft/lbs vs. 490 ft/lbs.)
It was said to have propelled the two-ton 300F near 170 mph.
AMC a Mopar? Stop the nonsense! SpiritRT Hotrodders' Lounge 19 09-12-2012 04:05 AM
Comments on 413 Mopar Dragon J Engine 13 01-28-2011 11:57 PM
Mopar Rears rj57 Transmission - Rearend 2 04-28-2008 05:22 PM
Are 413 mopar engines any good? chevelle4542speed Engine 13 08-21-2006 11:28 PM
400sbc V 400 Mopar Fletchy Introduce Yourself 1 11-22-2005 07:16 AM
