Are 413 mopar engines any good? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2006, 10:47 AM
well i have i 413 dodge motor that came out of a motor home are they any good? better than a 440?
Old 08-19-2006, 01:10 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Fine engines. Just a smaller bore 426 or 440. Making it 426 is a stretch, and 440 is impossible.
Old 08-19-2006, 02:42 PM
Gene Davis's Avatar
Strker
413's are great engines. I've built 413's, 426's and 440's which will run door to door with each other. True enough, the 413 was dropped fairly early on in the horsepower race of the early '60's, but it was a real torquer and the main reason trucks and motor homes wound up with them. Stock for stock, a 383 would run side by side with a 413. Now, whatcha gotta do is take the best of all the HP big blocks and use those parts in your 413. Flat-top pistons and a set of 906 (casting number) heads, or perhaps a set of 2.08" closed-chamber heads will work really nice. You may have to do a bit of valve seat re-sizing for the 2.08" intakes in those closed-chamber heads, but they are "killer" heads. A set of Stage V heads would be awesome. They can be gotten with 2.25" intakes, and 1.88" exhausts. Breathing is the key to producing power. The lower end of that particular engine is excellent as is. The pistons, however, are going to hafta be exchanged for some good after-market ones. If you are going to use it on the street, go with flat-tops. If you are going to bracket race it, go with an 11:1 pop-up. Before doing anything, determine what kind of gas you are going to be using. Pump gas,..flat-tops. SoCal, or VIP gas, go with the pop-ups. Grinding the casting flash off the interior walls will aid in returning oil to the pan quicker. Oil galleries on each side of the camshaft should be ground smooth as well. Be sure you use a windage tray to avoid the crank spashing in the oil. Oil splash can really slow your rod down. Of course, nobody would build anything without getting it balanced. You may want to knife-edge the leading edges of the crank throws. This acts like a knife flying around in the oil dripping back to the pan. If I can be of any help along the way, contact me by e-mail. Good luck!
Old 08-19-2006, 04:21 PM
well i have 3 440 motors and i heard that the 413 is a wedge motor doesnt that mean the heads are wedge shape? , maybe put those heads on the 440.
but i am going to build the 440, just thought those heads were good ones maybe?
Old 08-19-2006, 08:20 PM
Wiki Edits: 49
You need to do a little more reading about Mopar engines before you tear into one, the 413 is basically identical to the 440 except for the bore size, heads included. The wedge engines were the 361, 383, 413, 426 and 440. The 426 hemi was derived from the 426 wedge in '64.
413's are terrible. As a matter of fact you should get rid of that one immediately. Just send it to me COD.
Old 08-20-2006, 08:23 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Pretty much agree with the rest, the 413 is a very good engine. Not "better" than a 440 just a smaller version. Perfect for a nostalgia rod or 60's Mopar. They are to Mopar what the 409 is to Chevy or the 406 to Ford. Ever listen to the Beach Boys Shut Down ? "Pedals to the floor, hear those dual quads ring"......... There was a 413 Fury in town when I was a teenager and it was pretty impressive for a "boat", it held it's own with more than a few musclecars. They will run hard and respond to the same mods as any other Mopar B or RB block. Not a Mopar guy myself but if somebody wanted to give me one I sure wouldn't say "No."
Old 08-20-2006, 08:45 AM
xntrik's Avatar
Originally Posted by Gene Davis
413's are great engines. I've built 413's, 426's and 440's which will run door to door with each other. True enough, the 413 was dropped fairly early on in the horsepower race of the early '60's, but it was a real torquer and the main reason trucks and motor homes wound up with them. Stock for stock, a 383 would run side by side with a 413. Now, whatcha gotta do is take the best of all the HP big blocks and use those parts in your 413. Flat-top pistons and a set of 936 (casting number) heads, or perhaps a set of 2.08" closed-chamber heads will work really nice. You may have to do a bit of valve seat re-sizing for the 2.08" intakes in those closed-chamber heads, but they are "killer" heads. A set of Stage V heads would be awesome. They can be gotten with 2.25" intakes, and 1.88" exhausts. Breathing is the key to producing power. The lower end of that particular engine is excellent as is. The pistons, however, are going to hafta be exchanged for some good after-market ones. If you are going to use it on the street, go with flat-tops. If you are going to bracket race it, go with an 11:1 pop-up. Before doing anything, determine what kind of gas you are going to be using. Pump gas,..flat-tops. SoCal, or VIP gas, go with the pop-ups. Grinding the casting flash off the interior walls will aid in returning oil to the pan quicker. Oil galleries on each side of the camshaft should be ground smooth as well. Be sure you use a windage tray to avoid the crank spashing in the oil. Oil splash can really slow your rod down. Of course, nobody would build anything without getting it balanced. You may want to knife-edge the leading edges of the crank throws. This acts like a knife flying around in the oil dripping back to the pan. If I can be of any help along the way, contact me by e-mail. Good luck!
Why spend all that money on a 413 when you can build a 440 for the same price and make more power across the board? More cubes and bigger bore= better breathing = more power.
www.readershotrods.com see readers' rides
Old 08-20-2006, 10:56 AM
Gene Davis's Avatar
Strker
Re: Are 413 mopar engines any good?
xntrik, you are absolutely correct, however, I'm assuming that chevelle4542speed already has a 413 and wanted to do something with it. I totally agree that a 440 is the way to go, but "a bird in hand".....
Anyway, with the right parts, the 413 will fly. My first wedgie was a 413, and nobody could beat me at the local dragstrip,....that is until I ran into a 426 Max Wedge. But I had almost two years to enjoy the fact that I was the king. chevelle4542speed, I would just ponder what you really want to do and go with your gut. Remember, ALL RB goodies will inter-change (I have a rather nice collection of HP parts and goodies for B & RB engines ) with your 413, so, really, the ball is in your court. Good luck, Stroker.
Old 08-20-2006, 12:38 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
There was also a 350 cubic inch motor in that line up of old Mopar engines
Old 08-20-2006, 12:47 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
413 Golden Lion
413 Cross Ram
Torque Monsters---Something had to get those New Yorkers rolling
I think these were about 385# torque at 2800rpm bone stock in 1959
By standards of the day-----AWESOME
Bryan
Old 08-20-2006, 01:03 PM
xntrik's Avatar
Gene Davis,
how would you get 2.25 x 1.88 valves into that smaller 4.1875 bore. Would you notch the cylinder walls? Valve shrouding?
There isn't much in the way of 413 performance pistons out there. Wouldn't custom made pistons be quite expensive?
http://www.snopes.com/politics/soapbox/lamm.asp
Old 08-20-2006, 01:17 PM
Wiki Edits: 49
Originally Posted by RPM
......There was also a 350 cubic inch motor in that line up of old Mopar engines
Quite correct. There was also the 400 "B" block as well. Sometimes I suffer from CRS I guess.
Old 08-20-2006, 02:31 PM
xntrik's Avatar
I don't remember what CRS means.
Old 08-21-2006, 11:28 PM
"Can't Remember Stuff"
good cam for me? 89silverado454 Engine 4 03-21-2006 08:54 AM
crankshaft 241 259 (260) 270 engines tend to crack Edwin Engine 8 01-16-2006 05:40 PM
Good Grounding can make a difference ep33510 Electrical 2 12-07-2005 07:42 PM
350 and good gas milage and a combo HELP changer01 Engine 7 09-22-2003 11:05 PM
Need a set of old no good heads to teach kids how engines work Blue_Blazer Engine 1 08-07-2002 01:48 PM
