4150 Double Pumper Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2006, 09:42 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
I am not much of a tuner so I am hoping you guys can help with some suggestions. I have a 600 cfm 4150 Double Pumper, Mechanical Secondary, Manual Choke Holley on my Model T Roadster. The motor wants to stall in stop and go traffic when I apply the brakes. Especially true if I really nail the brakes, doesn't stall if brakes are applied easily but stumbles a bit.
Other than this it runs fine. Tranny is a manual 4-speed and the car has manual brakes, no power anything. Stock freshened up small block Ford 5.0 HO roller cam motor circa mid to late 1980's. Low compression 8 : 1.
I hate to start screwing around with the carb, cause like I said I ain't a tuner. But seeing how I built the entire car myself I ain't skeered either. Just don't want to take two steps forward and four steps back.
Thanks in advance
Old 08-01-2006, 10:24 PM
302 Z28's Avatar
Sounds to me like the float level may be set too high.
Vince
Old 08-01-2006, 10:41 PM
camaroman7d's Avatar
I agree that was my first thought. Check your float level. Gas should just seep out the hole .
Old 08-03-2006, 08:58 PM
Thanks for the advice.
Holley Double Pumper Question... Blazin72 Engine 9 01-07-2006 01:50 PM
Chevy question Ratoflic Hotrodding Basics 1 11-02-2005 10:55 PM
Holly 4150 question. kd5boc Engine 12 07-31-2005 08:31 PM
Holley 4150 / timing question 70bird Engine 6 04-01-2005 08:19 AM
carb Joe_Alan216 Engine 5 06-28-2002 07:59 PM
