416 sbc heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2007, 05:23 PM
brandon624's Avatar
416 sbc heads
Does anybody know how many ccs' a 305 casting# 416 is supposed to have? I have a set I may use. I've read some 305 heads only have (roughly) 54cc combustion chambers, which would have to be the smallest stock chevy chamber I've heard of.
Old 10-15-2007, 07:21 PM
58cc is advertised, they're probably a little bigger like all you measure.
Why a 416, while good enough for a 305, they're under valved and undersized for anything bigger. Modified with larger valves and ported just short of hitting water they were a rage several decades back before Mr. Ricardo's' head studies were rediscovered in the mid 1980s. Rebuilding these 305 heads is fairly expensive and the result won't hold a candle to a set of Vortecs. So you need a really good reason to go down that road.
Bogie
Old 10-15-2007, 08:02 PM
E.T. divided by $ spent= Speed
416 casting on a stock dished piston 350 makes for a lowend monster.Those heads bump the compression up to over 9.5:1 and those small ports and valves make it responsive in the lows.Fun for quick blasts. The motor I had like that only made power to like 4800rpms with a 214/224@050 cam but it was snappy.
The Following User Says Thank You to 78 monte For This Useful Post:
Buick b4 (12-13-2015)
Old 10-16-2007, 02:48 AM
brandon624's Avatar
Right now I have a 307 with a set of powerpack(58cc) 896 castings, that I have ported and parallel milled .090" off of. I also port matched and milled a cast iron intake to fit. This made a VERY NOTICEABLE difference in performance, and I really liked the higher compression. I was considering using the 305s, but for my new project I can only mill about .030" off, and I don't want my compression to drop too much.
Old 10-17-2007, 02:05 PM
brandon624's Avatar
Thanks for the reply. 601s eh'. I may look for set. I like ford 289 chambers, those are some serious compression makers.
SBC cylinder head bolts .. cast iron heads Vs Alum. heads terror385 Engine 3 08-04-2006 08:34 PM
SBC heads NOlowrider Engine 6 03-27-2006 09:34 PM
getting old iron heads to flow? (SBC) KNanthrup Engine 9 12-21-2005 05:06 PM
Swapping heads on a 383 SBC 72Nova383 Engine 5 03-06-2005 04:55 PM
sbc heads sb72elcamino350 Engine 13 10-30-2003 08:53 PM
