4160 to 4150 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2013, 05:08 PM
4160 to 4150
I have a holley 4160 750cfm vacuum secondary. I have the primary running pretty good. I have 72 jets in the front. But probablly need to go to 70 or 68. I want to convert it to a 4150 to have a little more adjustability. What would be a good starting point for the secondary jets? I think the secondaries are generally richer than the primaries but not sure on that. Should I get a secondary metering block with a power valve? I would assume not since my other 4150 carb doesn't have one. What would be the disadvantage to a secondary power valve? Anything else you guys can point me in the right direction on?
Old 02-21-2013, 09:00 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Use another Holley Carburetor of similar CFM as a point of reference. I did the same thing on my pair of 390 VS Holley for my TR setup. I Change it from a sec. plate to a block.
Holley carb specifications, list #'s, jetting and tuning tips.
The Following User Says Thank You to lg1969 For This Useful Post:
bowtie44s (02-22-2013)
Old 02-22-2013, 04:23 PM
ericnova72's Avatar
More for Less Racer
No powervalve in the rear block, Start with #80 jets and tune from there. This is Holley's starting point for 750 vacuum secondaries with no powervalve provision in the rear and a rear metering block with replacable jets.
The Following User Says Thank You to ericnova72 For This Useful Post:
Old 02-22-2013, 06:39 PM
Just wondering why I don't want a powervalve in the rear. My theory is if i'm at low vacuum with just the primaries open the 2nd powervalve will open and cause it to run rich. Am I correct or way off? Is that why the secondary jets are so big?
Old 02-23-2013, 02:54 AM
Yes and no. The power valve in the primaries are sufficient enough on that carburetor to keep that hesitation out when you romp on it.
If you put the same power valve in it as the one in the primaries, you wouldn't have a problem, except it'd still run rich because the primary power valve is doing the job well enough. More isn't better.
13.8:1 air to fuel ratio is perfection for power.
Old 03-01-2013, 04:17 PM
ericnova72's Avatar
More for Less Racer
Also, under hard accelleration the fuel in the rear bowl sloshes to the rear of the bowl, away from the pick-up point of the rear powervalve, it is slightly higher on the metering block than the jets are. This is the main reason Holley discontinued use of rear powervalves in most on thier carbs.
Rear jet extensions are used on hard launching cars for the same reason, to move the jet back to where the fuel is forced to be due to the G-force of the launch.
You're correct, the rear jets are bigger because there is no additional fuel being added by a powervalve like there is in the front.
holley 4160 to 4150 conversion help needed eric32 Engine 10 12-19-2009 05:12 PM
help with holley 4160 sam_bo3 Engine 2 03-11-2009 06:10 AM
4160 600cfm StevenC Engine 1 01-04-2006 04:50 AM
Powdercoating a Holley 4160 rick458 Engine 6 03-21-2005 01:26 PM
Flanges on 4160 Holley's the same as 4150's? unstable Engine 5 06-28-2004 08:54 PM
