-   -   421 cam (http://www.hotrodders.com/forum/421-cam-154770.html)
69Caprice 03-10-2009 10:40 PM
421 cam
Hey guys I'm back with the led sled, i need cam suggestions for a sbc 421, in 69 caprice, I have ac, I want good braking, good power, I have 373 gears, seeking lopey or choppy idle, afr 210/76 heads, interested in hydraulic roller!
techinspector1 03-10-2009 11:06 PM
What's the static compression ratio?
k-star 03-11-2009 05:56 AM
cam
Need the static compression. (real not a guess)
Weight of the car and what converter you are running.
Are you willing to spend the money for a custom grind or do you want a shelf cam???
Keith
69Caprice 03-12-2009 06:31 AM
The static compression ration is 10.5:1
69Caprice 03-12-2009 06:34 AM
Keith
Car is 4200lbs(heavy) street cruiser but I want power! 3000 converter don't know the best option with off the shelf or custom grind but if I can go off the shelf with decent performance I'm for it.
