421 SBC not making power - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-14-2013, 07:07 AM
Banned
Originally Posted by yorkcounty View Post
Yes it is electric and I have a 10 gauge wire ran to it. I have it ran through a relay off the switch. It's approx. 4 feet from the fuel cell under the truck.
Now the return line issue is very interesting. I am running a deadhead style regulator to the carb. I have 3/8 lines from each side of the regulator to each bowl but no return. I do have a pressure gauge inline and I'm on 7-8 psi.
I wasn't aware that the electric pumps stop after reaching pressure so to speak.
electric pumps DON'T STOP but the dead head regulator shuts off the fuel flow, and then the pump just sit's and spins, the fuel is what cools the pump, and is what lubes it.. what psi you have after you top out 1st gear, the fuel being stopped at the deadhead regulator, and your using it at WOT is your issue, the pump can't get the fuel to move in the 1/ line fast enough.. and the fuel volume in the line works against you..
looss the dead head and add a return line,, problem solved
  #17 (permalink)
Old 02-14-2013, 12:31 PM
Do I even need the 1/2 line? Can I just leave the 1/2 to the pump and then go back to 3/8
  #18 (permalink)
Old 02-14-2013, 02:10 PM
Banned
yes you can use 3/8's for the return, the fuel moving in the line at all times will help tons, as the psi drops in the line (regulator to carb,) there will be no delay when the regulator opens flow to the carb..
as the column of fuel will be moving, remember as you run through the gears the fuel in the line wants to go backwards, adding to the load to the pump.. with it always moving forward (an item in motion stays in motion) when you need the fuel it'll be there..
make sure you didn't kill the pump with the deadhead regulator and no flow through the pump to cool it..
even after the return line, make sure you have 5-6 psi at carb at the top of every gear..
  #19 (permalink)
Old 02-15-2013, 12:29 PM
have you had the carb updated! same thing happened to me one time, it drove me crazy, over the winter the carb builder had changed something in the carb metering plates from tubes to jets, it ran great on the dyno but would fall down on the track. he fixed all three carbs.
How to Build a 421 SBC ??? Chevy406power Engine 10 11-06-2010 05:45 PM
421 sbc Hick_101 Engine 61 04-07-2010 10:30 PM
sbc 421 monster mouse Engine 0 11-27-2009 12:59 PM
421 vs 434 sbc 69Caprice Engine 14 03-05-2009 03:42 PM
Stroke on 421 sbc? Need4Speed Engine 0 09-01-2002 08:56 AM
