#1
421 vs 434 sbc
Hey guys! Will a afr 210/76 heads be compatible with a 10-10.5:1 pump gas 434 sbc? or will a 421 sbc be more suitable? These are the race ready version heads, im putting in a 69 caprice!
Register now (free) or login to remove ads |
#2
Heavy car + $15,000 race 434 small block = you can afford whatever heads you want.
#4
Those heads should be fine. If you're going to spin the motor up to high RPMs I'd consider the Brodix X-11s and have them CNC'd by Brodix.
#5
Yeah, but 434 starts with a raised-cam, wide rail motown block, then has a buttload of machine work and custom parts; crank, rods, pistons, wider oil pan, specialty timing chain and valvetrain, and massive heads to feed it. If he's putting a $15,000 race engine in a behemoth 69 caprice, then he already has enough money to throw at this project and doesn't need our help deciding on a 434 or a 421... and how do you make a 421 SBC anyway? |
#7
Ah...ok. My math was off... I thought that made 420.
I'm just skeptical, because in two and a half years, this guy has made three posts. One talked about a 406, this one talking about a huge-budget 434, and one that just said "waz up". I'm just being a jerk That's all.
#8
Hey, I'm a jerk on most days. And I wouldn't waste all of that money on a stock 400 block, but you can do it with off the shelf parts if you are so inclined to. If I was looking at those power levels I'd just run a Gen IV engine. |
#9
By the way... what stock block can be clearanced for 4" stroke without hitting water or cam? I thought that was strictly raised cam, wide pan rail territory.
#10
Most blocks can with the new rods that are out. Look for 4" stroke kits, you'll see them used to turn 350's into 400's. I forget who all manufactures them, I think SCAT may. Like I said though, when you're dumping 2G's into a rotating assembly, and 2 into heads, it kinda makes sense to put another 2 into a good block. |
#13
Then why are you asking us? Give your plastic to a reputable builder and sign the tab when its done. |
#15
If you've got 15 grand to spend, a 502 Big Block would be a much smarter place to start with that heavy of a car.
| Thread Tools | Search this Thread |
| Similar Threads for: "421 vs 434 sbc" | ||||
| cam & cylinder head recommendation for 434 sbc | sunnyday | Engine | 3 | 07-27-2008 09:54 AM |
| 434 sbc...what fuel system should i run? | 68SSMaro | Engine | 5 | 05-08-2004 03:10 AM |
| sbc 434 stroker | sb72elcamino350 | Engine | 11 | 03-17-2004 10:19 AM |
| sbc 434 stroker | sb72elcamino350 | Engine | 0 | 03-09-2004 11:17 PM |
| Stroke on 421 sbc? | Need4Speed | Engine | 0 | 09-01-2002 08:56 AM |
