425 and 455 oldsmobile engine swap?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2007, 12:32 PM
425 and 455 oldsmobile ??
Hi will a 425 olds. motor interchange with a 455 olds. I found a 1965 olds. tornado with a 425 motor. Would like to install it in a jet boat that had a 455 olds. in it. Any suggestions? Thanks Danny Sorry this post was suppose to be listed under motors don't know how to move it.
Old 10-28-2007, 02:16 PM
Anyone know if they will bolt up?
Old 10-28-2007, 02:25 PM
Mustangsaly's Avatar
I think the 425 & the 455 BBO is the same. but you should ask over at www.realoldspower.com, theres even a section there for Olds powered Boats. theres some Olds Horse Power Nuts there, enjoy.
Old 10-28-2007, 04:29 PM
Tried that for some reason will now let me register.
Old 10-28-2007, 04:55 PM
Old does not mean dumb
The 425 is a direct swap for the 455. Good chance the crank in the 425 will be steel. (an added plus) and the toronado engines have a deeper oil pan for that extra oil...
Old 10-29-2007, 10:56 AM
All big block Olds motors are externally identical but there are a few things that you need to be aware of:
The Toro wasn't released until 1966, so be sure you know what you're getting.
ALL 425 Olds motors have forged cranks.
The 64-67 Olds motors used a different crankshaft flange bolt pattern than the 68-90 motors. You must use the flywheel or flexplate for a 64-67 motor. The flywheel from a 455 will not work.
The Toro used a different oil filter adapter than the RWD cars. I don't know what's in the jet boat now, but use that one.
The Toro used different accessory brackets than the RWD cars. Also, the 64-67 motors used brackets that had some differences from the 68-up motors. I assume you'll just use what's already in the jet boat now.
Olds used different length water pumps. A/C and HD cooling pumps were longer than non-A/C pumps. The pump, pulleys, and brackets must be used as a matched set. If this boat installation uses a flat front cover with a remote water pump then this doesn't apply.
Old 10-29-2007, 02:20 PM
Thank you all Danny
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
Oldsmobile heads question. 87442lover Engine 9 12-11-2009 02:56 PM
fastest muscle pre 1970 81elcamino Hotrodders' Lounge 86 01-19-2009 04:53 PM
crown for king of the muscle cars Quarter mile killer Hotrodders' Lounge 48 08-20-2005 10:31 AM
