Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 425 Caddy into a Stroker 454
Old 04-20-2013, 11:02 PM
1971BB427's Avatar
1971BB427 1971BB427 is offline
Originally Posted by WDCreech View Post
You chevy guys are all the same! You think chevy is the only way. A 425 Caddy is about 60lbs lighter than a BBC. So how much weight are you going to save by going with aluminum heads on the belly button engine?
Bill
No, I did not tell him "Chevy is the only way". I suggested a 500 Caddy is a better choice, and since his post is revolving around the 425 being lighter than a 454 Chevy, I suggested he save both weight and money with an aluminum head 454. If that gets your tidy whiteys in a bunch, it's how you read it, not anything else.
The weight savings per head is 50 lbs., so it's 100 lbs less with aluminum heads vs. cast iron in a BBC. So 40 lbs. lighter than the non belly button 425 Caddy.
You Chevy haters are alwways looking for a reason to knock a Chevy engine, big or small.
