425 cadillac engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2006, 09:26 PM
425 cadillac engine
I hope someone has had this problem......This is a new rebuild engine, I have it in a 1947 Cadillac that I'm building. heres the problem. it will not idle with the choke opened with choke closed about 1/4 way it runs great. this is the no. carb. someone told me it could be in the dist.[factory dist] wou;\ld appreciate any help..........thanks all
Old 01-24-2006, 09:28 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
WELCOME TO HOTRODDERS.COM
The Most innovative Site on the Net
Thanks for joining
Post your"Q"n the engine forum to get the best "A"
"SlowRide66"
"Illegitimis non carborundum"
Old 01-25-2006, 12:49 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders , we are glad to have you here. Enjoy the site.
Old 01-25-2006, 06:35 PM
poncho62's Avatar
Wiki Edits: 5
moving to engine forum.
Old 01-25-2006, 07:13 PM
ckucia's Avatar
I'm not sure if I can help all that much, other than to get some clarification on the details.
If its a 425, then it is from a 77,78 or 79 Cadillac.
Are you using the carbed manifold or the FI manifold?
Are you using the distributor off the stock 425 (should be HEI?) or the one off the '47?
Are you using the stock Q-jet from the 77/78/79?
Old 01-25-2006, 08:07 PM
sbchevfreak's Avatar
Licenced Automotive Technician
If the choke must be closed slightly, it usually indicates a vacuum leak or lean condition. My advice would be to look for vacuum leaks, ckecking the throttle shaft for radial play, intake, vacuum lines, ect. As was already asked, is it the Q-jet, or another carb? For nearly any carb, especially Q-jets and holley, remove it and check the screws that attache the throtthe body to the carb body. These have been known to come loose and provide a hard to find vacuum leak.
Old 06-06-2007, 02:00 AM
mrbull30's Avatar
I was wondering what kind of tranny you have the 425 bolted to i was wondering if it fit a turbo 350 or 400
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 04:05 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
DUI Distributor & 1970 Cadillac engine Coodeville Engine 4 01-02-2010 03:02 PM
My 1600 mile engine Kevin45 Hotrodders' Lounge 6 11-21-2005 05:53 PM
New Engine Built & Dyno'd babe_n_indy Engine 69 09-09-2004 07:26 PM
