425 high comp - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2014, 02:00 PM
425 high comp
Hello there i am new to this cite and new to hot rodding.I have a 1966 olds 4 door dynamic 88 with a 425 high comp engine that runs good but being new to hot rodding i am looking for some basic info on this motor,what is it?and what should i be looking for ect...thanx,vern
Old 06-15-2014, 02:05 PM
ericnova72's Avatar
More for Less Racer
1966 425 high compression engine is 425 cubes, forged steel crank, has one of the preferred Olds big block head casting's on it, ...10.25-10.5 to 1 compression, and rated at 380 hp IIRC.
You'll be able to find a good deal of info at WELCOME 442.COM in the FAQ section.
Old 06-16-2014, 05:22 AM
The 425 Olds is nearly identical to the later 455 Olds. The primary difference is the stroke. Some mid-1960s Olds motors used unusual lifter diameters and bank angles, so you need to be sure you know what your block has if you plan to change cam and lifters. Otherwise, it's a very strong motor. As I noted in your other thread, this car is not popular, so don't expect to find things like headers to fit it.
Old 06-16-2014, 10:24 AM
Let me add that if you want dual exhaust, about the only way to do it on this car is to use the special factory driver's side exhaust manifold that is shaped to clear the steering box. Fortunately, these manifolds are reproduced.
1965 -1970 Starfire Dual Exhaust Manifolds
High comp 4.1 Buick piston q? 77amc Engine 0 08-23-2012 09:58 AM
performer 100cc high comp 454 ekacpuc Engine 5 03-26-2010 03:24 AM
Built a High Comp chevy by mistake ... need help TerroRx7 Engine 4 10-05-2006 02:05 PM
high comp. 383 stroker, any ideas? Troll_Killer Engine 8 07-18-2004 12:50 PM
78-87 G-Body high comp. spring gave bad alinement MuscleBlock81 Suspension - Brakes - Steering 5 03-14-2003 04:22 PM
