426 Hemi dual 4's - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2013, 10:07 PM
426 Hemi dual 4's
Have a 1967 GTX 426 HEMI dual 4's. Idle's and starts good. Runs up to about 1800 to 2000 rpm and when trying to get any higher rpm the engine boogs and backfires out the intake. Reset both points to 27 degrees and total 38 degrees according to the book. Reset timing to 8 degrees and tried to checked total timing advance but could not get the engine to run good enough to check. The timing would advance when rpm was raised though. Rebuilt both carbs and checked for air leaks. Has good vaccumn and good compression. This engine was rebuilt and had been run for 500 miles then stored for 25 years. I replaced all seals and checked bearings and used a bore scope too check the heads for rust. I did not pull the heads because they looked good. The linkage to the carbs are set so the back or rear carb opens the throttle plate first so I assume the engine runs from idle to about 2000 rpm on the the rear carb, then opens the front carb with higher rpm. This is when the engine boogs and starts cutting out or poping out the carb. Where should I look next?
Old 04-30-2013, 12:39 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You replaced all the seals, inspected the bearings, looked in the cylinder with a bore scope for rust but didn't pull the heads or intake? You had to have pulled the motor, put it on a stand to pull the pan, rod and main caps. What seals did you replace?
Semper Fi
Old 04-30-2013, 04:16 AM
poncho62's Avatar
Wiki Edits: 5
Just a guess...weak valve springs from sitting 25 years
Old 04-30-2013, 04:46 AM
Banned
Originally Posted by poncho62 View Post
just a guess...weak valve springs from sitting 25 years
b.i.n.g.o.
Old 04-30-2013, 05:45 AM
engineczar's Avatar
My guess is it's fuel related. What you're saying is that as soon as you begin to open the front carb it pops. ie a lean pop.
One thing to try is to disconnect the linkage to the front carb so it doesn't open. Then see if it will rev higher on just the rear carb.
Check the float levels, accelerator pumps, etc
BSE Racing Engines
Old 04-30-2013, 09:21 AM
Fang16's Avatar
Last journal entry: Project change
Check the vacuum at idle and as u accelerate. I have seen cases where the exhaust has closed up, usually with a double wall pipe. The inner pipe collapses and you can't see it. Even found a couple of big rat nest in a pipe onetime.
426 street hemi bigblocklover Engine 6 08-04-2011 09:40 AM
Own a 426 Hemi for $50!! willys36@aol.com Engine 6 10-28-2004 08:16 AM
426 Hemi SuperBee Engine 3 08-24-2003 07:26 AM
426 Hemi block kingtogar Engine 0 08-17-2003 10:18 PM
New 426 Hemi Engines..... Bent Wrench Hotrodders' Lounge 2 06-08-2002 02:35 PM
