427 in 3/4 ton - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2006, 08:36 PM
moy moy is offline
427 in 3/4 ton
hi can anyone help me. i have a 427 casting 473478 i was wondering what i need to put it in my 82 3/4 ton chevy truck. i'm new to this and i would really appreciate it thanks
Old 07-31-2006, 10:15 PM
Bumpstick's Avatar
Hammer and a torch
Since its a 3/4 ton truck to begin with then nothing more than a good turbo 400 trans behind it and all the reg brackets/pulleys and exhaust for a BBC... BTW that is a really good block to build on... Its the 4 bolt main version and is the std. deck according to Mortec.com
Oops it is a tall deck block...
Old 07-31-2006, 10:27 PM
moy moy is offline
thanks
a good solid answer is what i needed thanks alot
Old 08-01-2006, 06:15 PM
nitro_baller4692's Avatar
floppers forever
i was just at motec.com and it is a tall deck that is what the t is for after the 427,thats what the key at the bottom of the page says.this is a 10.200'' deck height.but it is a 4 bolt main.thats a truck block all tall deck are,the heads will have castings that say truck,pass,or hi perf.that will be stamped on the head.make sure you use the correct intake with the correct head.
that is a great block to make a lot of torque,a good stump puller if you know what i mean.
Old 08-01-2006, 08:18 PM
Bumpstick's Avatar
Hammer and a torch
Yep he is right (my bad might be the 12-16 hour days...? ) its a tall deck block but still a good platform to use... Goobs of torque to be made which works real good with the extra weight of a 3/4 ton truck...
Sorry did not notice the "T" note at the bottom as I was thinking of the pad numbers which if it has a T in it then it was just known as a truck block which could be either deck height...
Old 08-01-2006, 10:13 PM
moy moy is offline
the engine is all original should i change any thing?
Old 08-02-2006, 10:01 AM
floppers forever
what will the truck be used for?will determin how to build the engine.
3/4 ton Chevy Semi Float to Full Float Swap Rob Keller Transmission - Rearend 2 05-18-2006 12:23 PM
1987 3/4 ton cab on a 79 shortbed frame? hiball Body - Exterior 4 12-08-2005 05:28 AM
Rear Leaf Suspension 49 Chev 3/4 Ton, Suggestion Needed! lazydawg Suspension - Brakes - Steering 1 09-06-2005 06:32 PM
3/4 ton lug pattern 406chevelle General Rodding Tech 8 01-22-2005 11:49 AM
88 chevy 2 ton cab to 80 3/4 ton frame stoneyone2001 Body - Exterior 1 11-11-2003 08:43 AM
