Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #46
Old 06-04-2005, 09:36 PM
Lonestar's Avatar
Lonestar Lonestar is offline
"May the Schwartz be with you"
 Lonestar's barnstar
re: 427 or 454?
Originally Posted by Tiros
It is you who attempted to take ME to school!
You flat out tell me I'm wrong than attempt to back it up with a lesson on Ohms law!
This is what I said:
And your Reply:
Why don't you explain to me again why my initial post is incorrect.: You tried and you CANT!
Nowhere in your rant did you mention POWER, No where at all!
You tell us, in detail how transformers work, and give a whole lesson on ohms law that does ABSOULTELY NOTHING to refute my original post. You insist that if voltage goes up current must also. Duh. Since I was discussing power line transfer, and you failed to mention power at all, there seems to be no indication from your post that you were even aware of this. Your reply certainly did nothing to disprove my point. Now you try to say you agree and I am only validating your point?
I Never said you could "play with it". As a matter of fact I said "relativley" low current. Do a search on "relative". The current is lower RELATIVE to what is being delivered to the low voltage loads. Get it now? This is the point that set you off. You only solved part of the equation. You ignored POWER. You only considered voltage and current. Your bad.
FYI:
I can produce enough current with 120V (or less) to kill you. It only matters if your body resistance is low enough. SAFETY is not why it is stepped down, It is stepped down to recover the current that you need for your home. It is stepped down because your house can't use 24,000 volts.
This is what you said:
Please quote where I agree/repeated what you said about the insulators.
As I said, those insulators are used to prevent arc over from high VOLTAGE not high CURRENT. I can surely send 1000 amps (or more) down a wire at low voltage (lets say 12 volts) and I wont need a mica insulator. Wood would work fine. Even at 1000 amps. 12 volts will NEVER jump an arc through the air.
Lets see now:
1) Explain what was wrong with my first post.
2) Explain why wood can't be used for high current, (not high voltage) insulation.
3) Quote where I agree/repeated what you said about the insulators.
4) Explain why SAFETY is the reason why voltage is stepped down.
You tried to come off like some know it all and you got SPANKED!
You said I was wrong, now back it up or shut up!
Let the backpedaling begin!
I'm a bit confused here...are you saying the 427 has more current or voltage as compared to the 454 and which one would you suggest would be better in his 'Vette and why?
Does it take more amps or volts to get a car down the 1/4 quicker?
Old 06-04-2005, 09:46 PM
coldknock's Avatar
coldknock coldknock is offline
re: 427 or 454?
Both I think are needed to get it started. It takes a lot to get them big blocks started.
You can also distill alcohol from the insulating wood and use a little more timing and compression with it to go faster.
Larry
Old 06-04-2005, 09:55 PM
Bumpstick's Avatar
Bumpstick Bumpstick is offline
Hammer and a torch
re: 427 or 454?
If you were rowing across the desert in a canoe nude...?
How many pan cakes would it take to build a dog house...?
None... watermelons dont have hair...
This has gotten way out of hand...
Old 06-04-2005, 10:22 PM
Drewnashty's Avatar
Drewnashty Drewnashty is offline
sitis nam accelero
re: 427 or 454?
haha bumpstick ur awesome and so right this has gotten pretty carried away but it's been fun
Old 06-04-2005, 10:30 PM
topfuel's Avatar
topfuel topfuel is offline
ASE Certified Master Machinist
 topfuel's barnstar
re: 427 or 454?
I could have built any size BBC to go in my Biscayne, but I chose a 427 for a few reasons that parallel reasons to go with a 427 in the Vette. First is traction. I am running a 9" tire and I didn't want to radically alter the suspension. Second is the cost factor. A 427 can be built on a relative budget and make gobs of power. Third is of course, the cool factor. A 427 "belongs" in a 60's muscle car!
I could have built a 632 and told everyone it was a 427, but where's the fun in that.
Check it out on my car domain page.
http://www.cardomain.com/profile/topfuelperf
Old 06-05-2005, 10:12 PM
JSracing's Avatar
JSracing JSracing is offline
Nitro Junkie
re: 427 or 454?
You might have spanked something but it wasn't me lol
Sorry you took it so hard. I wasn't trying to sound like a know it all, just trying to help. I'm still right LOL
BYE!
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "427 or 454?"
409 Corvette? MI2600 Engine 18 06-04-2005 09:34 PM
1969 427 and 1970 454 camshaft specs sb72elcamino350 Engine 1 10-03-2004 07:11 PM
350 / 427 info needed ? x007 Engine 10 08-09-2004 11:14 AM
454 or 427 for 70 Chevelle? f100beatertruck Engine 3 11-25-2003 05:29 PM
454 with a 427 crank ratfink14 Engine 5 10-19-2003 12:56 AM
