My dual quad stroker ran o.k. with progressive linkage but better with straight linkage. Many 409 and other engines run progressive linkage with no ill results. I was told the blower helps with fuel distribution and that is why I was considering progressive linkage with the Predators. If the consensus is no then I will not do it. Like I said, Predators in dual form on a blower are new to me. If I wanted the easy route, I would build two Holleys and be done with it. But alas, I have never taken the easy path. Not to mention the Predators look fantastic on top of the 6 71.
