427 6-71 dual predator questions
I am putting together a 427 bbc 6-71 blower and dual Predators. My question is about the carbs. I have 1 race and 1 street. Can I run progressive linkage with the street carb as the primary? I have done alot of searching and specific info on these carbs is spotty at best. There is/was a fella known as predatorguru or somthing similar and I would really like to talk to him, or somebody that can help me out. I hope to find real world experience, not theory. Thanks for the time!
mrhp
Without getting too far into it, so this VVC principle is that something that changes the diameter of the throat or what? I know nothing of these carbs. Whats going on there? I jusy remeber they were all the rage for a while and they essentially looked like a jack in the box,,,box.
I have run Predators in single form with great success. The only reason it was removed was to meet class requirements, the engine had to make 15 inches of vacuum. The predator would produce 14.5-15 inches, but not steady. It was replaced with a 750 Holley and we made 15-15.5 inches. The performance of the truck stayed the same. I have never used them in a dual set up, progressive linkage, on top of a 6-71 before and am looking for some insight as to the fesability of this along with a beginning set up. Blower motors do not like to be run lean, and I would like to not hurt this new motor.
You don't want to run progressive linkage on a dual carb setup, blower applications included, fuel distribution is one issue.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
My dual quad stroker ran o.k. with progressive linkage but better with straight linkage. Many 409 and other engines run progressive linkage with no ill results. I was told the blower helps with fuel distribution and that is why I was considering progressive linkage with the Predators. If the consensus is no then I will not do it. Like I said, Predators in dual form on a blower are new to me. If I wanted the easy route, I would build two Holleys and be done with it. But alas, I have never taken the easy path. Not to mention the Predators look fantastic on top of the 6 71.
Straight linkage was JMO, you'll find lots of opinions I'm sure. I just wouldn't consider it on my bucket tunnel ram BB or the Nova 8-71 motor, even if it felt like it ran ok. On the other hand, I've had two '65 GTO's with progressive 3x2's, OEM...however, the primary carb is centered...
My thought was it would be easier to control/tune/one carb at cruise rather than use both to cruise on due to it would be splitting up the cfm to both carbs at low speeds. I would think low airspeed split up between both carbs may cause a concern. Maybe not.
predator carb guru
Hey Predator Guru, you out there?
Is he there?
When I call Predator all it does is ring. I have no idea who Doug Hall is or how to find him.
High Performance Carburetors by Predator Here's the tech info from that site... http://www.predatorcarb.com/predator_manual.PDF Last edited by techinspector1; 12-04-2012 at 05:42 PM. |
| First bbc 427, 3904390 heads questions | 1986c10 | Engine | 29 | 01-15-2012 09:07 AM |
| 427 BBC tall block questions | George4 | Engine | 3 | 10-06-2011 08:48 PM |
| Questions about my dual carb set-up | Z-Money Pit | Engine | 1 | 06-14-2011 08:54 AM |
| 427 questions | superrican | Engine | 7 | 03-13-2006 10:14 AM |
| a few 427 questions | leftoverchrisac | Engine | 8 | 10-22-2004 03:33 PM |
