427 Bbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2007, 08:44 AM
427 Bbc
Have .060. 427 Chevy, Block Has Been O-ringed And Am Using .062 Copper Head Gaskets, Will Hold Compression But Leak Water. Block Is Studded Any Suggestions?
Old 04-17-2007, 12:51 PM
327NUT's Avatar
Well if your block is sound (did you have it sonic tested?) then it must be your heads. Is water getting into the combustion chamber or into the oil?
Old 04-17-2007, 06:51 PM
poncho62's Avatar
Wiki Edits: 5
Sounds like a head gasket is leaking.
Moving to engine forum.
Old 04-17-2007, 08:17 PM
Bumpstick's Avatar
Hammer and a torch
Can you say "Pipe dope"...? Might be the head gaskets but doubt it...? To many times have I seen guys install head studs and not put pipe sealer or whats known as pipe dope on them...
Worth its weight in gold (err water)...
Old 04-17-2007, 08:38 PM
BOBCRMAN@aol.com's Avatar
A liberal coating on both sides with the red colored spray "HI tack" gasket cement will stop your coolant woes.. I see these guys have never used solid copper gaskets before...
Old 04-18-2007, 10:00 AM
Did you use some copper coating on that shim? Where is the water going? Dont forget that your intake may be leaking especially if it was angle milled.
Let us know whats going on.
Old 05-07-2008, 06:59 PM
waynejosie
High tac is back you won't weep when it stops your leak
Old 05-07-2008, 07:39 PM
techinspector1's Avatar
Wiki Edits: 326
I would guess that the o-ring is sitting too far proud of the deck. Copper will only yield so far and you need more thickness to absorb the ring. In other words, about 10% is the limit of elasticity. A 0.060" gasket uses 0.006" ring height above deck. A 0.040" gasket uses 0.004" ring height above deck.
Why are you using such a thick gasket?
building a bbc 427 inquiring_mind2 Engine 4 11-16-2006 03:18 PM
is a BBC 396 crank same as 427? bigwildgrin Engine 9 03-14-2006 06:37 PM
Bbc 427 z3pr Engine 7 01-07-2006 04:30 PM
427 BBC Timing 66Vette Engine 10 12-23-2005 01:36 PM
gas milage on a bbc 427 bet on black Engine 18 01-03-2005 01:32 PM
