Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 427 BBC tall block questions
Old 04-17-2011, 10:14 PM
stinger460 stinger460 is offline
the tall deck 427 is similar the standard 427 but hence the name tall deck, smaller bore longer stroke and lower compression makes for a lot of torque, not really designed for street or racing apps without putting a bunch of money in it, you could change the cam for whatever application you need, wouldnt use a tunnel ram thats more for top end motors, suggest a single 4 barrel with a dual plane intake and perhaps a 1" carb spacer. the carb is going to be determined by how much mods are done to motor and cam rpm range. go to holley web site to carb selector, will get you in ball park
