427 BBC tuning help - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-09-2012, 05:52 AM
http://www.chevyhiperformance.com/te...ild/index.html
Here is an example of a dome piston bbc with a set of stock heads requiring 42 degrees of timing for max power.
  #17 (permalink)
Old 01-09-2012, 08:07 AM
Nothing wrong with your timing compromise, IMO. Another thing you could try is a 1" 4 hole spacer on top of that manifold. It could clean up the low end/idle a little for cheap. It did on my tunnel ram, anyway. There have been many apples to apples tests that don't support all the hype about single plane manifolds being so terrible on the bottom end/mid range. Besides, for having your fun, it's an easy give away for how hard it pulls from about 3,500 to 6,500. And that's another reason to keep the total advance at 38 or so as, from my own experience, a couple of brews and some good dirt make the foot heavy and the ears deaf.
  #18 (permalink)
Old 01-09-2012, 05:07 PM
amen to that man... lol
when i get back home ill try playing with the vacuum advance a little more and see if i can get the can set to where it needs to be. or maybe ill just put a stop in the vacuum because it would probably be alot easier to get my inital to 24 with that than mess with my distrubutor.
its not just a question of max power, im all for that, but i dont want the engine to turn into a grenade either
355 SBC Tuning help jdheff1982 Engine 5 11-27-2011 10:10 AM
Help on Tuning Please.. 66Ponty Engine 8 08-10-2009 11:50 PM
Help tuning my SBC ScottRods2945 Engine 2 05-14-2007 09:26 PM
Help tuning my SBC ScottRods2945 Engine 1 05-14-2007 05:43 PM
New to tuning... wacko86mmm Hotrodding Basics 4 07-16-2004 05:51 AM
